Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 09-16-2012, 06:27 AM   #1
Panman
Panman's Avatar
Drives: 86 GTS
AMSOil distributors in Aust?
Can anyone recommend a source for AMSOil here in Oz (or even better Brisbane). Planning on using Signiature series 0w20 full synth.
Oil opinions welcomed also.
Panman is offline   Reply With Quote
Old 09-16-2012, 06:35 AM   #2
RJ_
RJ_'s Avatar
http://enginecare.com.au
RJ_ is offline   Reply With Quote
Old 09-16-2012, 09:05 AM   #3
os86
Drives: 2jz
You don't have to use 0w-20 oil, you can use 10w30 as its thicker and will probably be better suited.
Check out Subaru sti japan website they are promoting the 10w-30
os86 is offline   Reply With Quote
Old 09-18-2012, 01:12 AM   #4
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
http://www.lubricationmanagement.com.au/shop/ is another
You can't go wrong with the Amsoil OE/XL 0w-20. You'll void your warranty using the signature series as it doesn't have an API or ILSAC rating.
If you're in NZ you can get it from http://syntheticoil.co.nz/price-list...ewlist?catid=1
Why 10w-30 os86? The service schedule say use only 0w-20 or 5w-30. http://www.ft86club.com/forums/showt...597#post401597
They obviously require a thin oil especially on start up. All a thicker oil is going to do is create more drag on the engine robbing it of performance & economy.
Looking on the STi site they list 5w-40 which is just a generic oil they use across the range, it's not specific for the FA20. TRD is the same. http://www.sti.jp/parts/catalogue/br...8050ST060.html This would be fine on the track but to thick for everyday use. The latest FPV supercharged V8 run 0w-20 so I'd say a little 200hp 4cyl will be ok running it too.
In theory you could run 0w-20, 5w-20, 0w-30 & 5w-30 but check the pds first
SXE10 is offline   Reply With Quote
Old 09-18-2012, 04:37 AM   #5
Ryan1JZ
Drives: AE93, JZZ30, ZN6
could be due to the different climate in japan
Ryan1JZ is offline   Reply With Quote
Questions for Toyota Aust. newft86 AUSTRALIA 88 08-19-2012 12:08 AM
Subaru Distributors Corp sure74 BRZ First-Gen (2012+) — General Topics 44 06-14-2012 12:01 PM
Aust parts developers Slide AUSTRALIA 3 11-30-2011 10:21 PM
