Old 08-26-2013, 10:41 PM   #15
Turdinator
Señor Member
Turdinator's Avatar
You would know if it were from a bearing in there.
1974 TA22 Celica
2013 86 GT
Old 08-26-2013, 11:31 PM   #16
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Originally Posted by Dipstik-sportech View Post
We're thinking it's one of the balls from the no.4 transmission clutch hub the synchronizer key spring ball. Could this be the cause of all the grinding trannys?!
The plot thickens.
Muaddib is offline   Reply With Quote
Old 08-27-2013, 08:24 AM   #17
markitect
Drives: Scion FRS
If you've checked everything, and haven't found a problem don't forget it could have fallen in while they were building, and they just put in a new bearing without, making sure they got all the balls.
markitect is offline   Reply With Quote
Old 08-27-2013, 08:57 AM   #18
Dipstik-sportech
Dipstik-sportech's Avatar
I highly doubt that but I'm hoping.
Old 08-27-2013, 11:12 AM   #19
DJCarbine
Thupercharged
DJCarbine's Avatar
10 Schrute bucks that its somehow related to the shift detent system
2013 FRS
Vortech V3 11psi
Old 08-27-2013, 11:40 AM   #20
Dipstik-sportech
It might very well be but the grinding going into 4th makes me think synchro Friday or Saturday. I don't get how this fell out though that's what's baffling.
Old 08-27-2013, 03:20 PM   #21
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Mind blowing
kiichiro is offline   Reply With Quote
Old 08-27-2013, 04:26 PM   #22
Trigonx
Drives: WRB BRZ
Well it's coming out and apart this weekend. Does anyone know where to find an exploded diagram or An fsm for this transmission?
link to Service Manuel Thread - http://www.ft86club.com/forums/showthread.php?t=35279
Trigonx is offline   Reply With Quote
Old 09-02-2013, 02:59 PM   #23
Dipstik-sportech
So the tranny is junk. There's a flaw in the design of the synchro sleeve that allows the balls to be able to fall out causing the failure. My local subaru dealer says they can't get parts in time for my race this coming weekend and no one has a tranny lying around up here. 4th gear it self and the synchro sleeve with the balls and spring need to be replaced. Could this be the cause of all the 4th gear grinds we're having... I 100% believe it is.
Old 09-02-2013, 03:09 PM   #24
Ben_G
Drives: Blue BRZ
That sux dude.... subbing this thread to see if SoC gives you a hard time with this warranty...
Ben_G is offline   Reply With Quote
Old 09-02-2013, 03:15 PM   #25
Dipstik-sportech
I really doubt they will warranty it. My car is modded quite a bit and they claim that's why it failed.
Old 12-28-2022, 04:08 PM   #26
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I have occasional scratches when changing to 4th gear, today I was going to change the oil but I found this ball.
surely change to another used trans, but I wanted to know if there is any danger of using the car like this.
Ruben_86_ is offline   Reply With Quote
Using higher quality brake fluid vs using cheap but changing more often ayau Tracking / Autocross / HPDE / Drifting 41 06-14-2015 01:20 PM
How do I check the tranny oil? mashal Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 08-18-2014 03:03 PM
tranny fluid change Dispect Engine, Exhaust, Transmission 3 01-27-2013 11:31 AM
Is the auto tranny from a isf? WolfsFang Engine, Exhaust, Transmission 6 08-25-2012 09:25 PM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
