#15 |
Middle Eastern 86
Drives: RED GT86
Thanks a lot guys
, with things u guys have told me i went to the dealership, and told them that they have to provide the recommended oil for the car. Turns out they dont have the recommended oil is because they dont sell much of the gt86 here . So, they said they're going to contact there oil supplier, and see if they make it. If that doesn't work out I told what if i got the oil and u guys put it in, he agreed and said that it wont void my warranty.
#16 | |
Drives: Subaru BRZ Sport Tech Satin White
The VI additives stop conventional oil from getting too thin as it heats up. Synthetic oil really doesn't rely on VI to maintain correct viscosity, the oil is assembled or refined to ensure the heavy waxy elements that cause oil to thicken when cold just aren't there. The lower W number means the oil has equivalent viscosity to a straight weight oil of that number when cold, not when hot. A zeroW (0W 20, for example) means there is no straight weight oil with that viscosity when cold. It really matters what that W number is because that's the oil protecting your engine while it was up. VI additives were invented to protect your engine when cold, so that much lower viscosity conventional oil could be used. Conventional oil is not like synthetic. It matters which you use in some engines, such as our BRZ. |
| The Following User Says Thank You to Suberman For This Useful Post: | zooki (08-19-2013) |
#17 |
Drives: Asphalt FR-S
#18 |
Drives: '97 RSP JZZ30 GT-T
I assume factory warranty is the same all over the world..? Could be wrong
Germans>Japanese>Italians>Americans. Unless its a Corvette. |
#19 |
I keep seeing references to the first number representing viscosity when "cold". It is actually the apparent viscosity results during the Cold Cranking Simulator test at -35C for 0W oil and -30C for 5W oil which is not very relevant to the OP.
http://www.pqiamerica.com/coldcrank.htm Unfortuntately, it's difficult to tell what the oil's actual viscosity is at a given temp like 0C or 20C. A viscosity graph does give you sort of a ball park of the actual viscosity at a given temp (although it may not be 100% accurate either). http://www.widman.biz/English/Calculators/Graph.html Plugging in the Mobil1 N. America viscosity numbers at 40C and 100C for the 0W-20 and 0W-40, you can see that the viscosity of M1 0W-20 is 44.8 cSt's and 0W-40 is 75 cSt's at 40C/86F. As a comparison, M1 5W-20 is 49.8 and M1 5W-30 is 61.7 at the same temp. This probably represents a "cold start" for the OP. Most 0W-x oils, regardless if conventional or "synthetic" do contain Viscosity Index Improvers. Ester based 5W oils like Red Line or Motul 300V usually contain less or no VII's, but most companies (even Red Line) need to add them to the 0W-x oils to meet the CCS spec. You can contact Red Line for details. AZOOZ, it's good that your dealer is trying to get the right oil for you. :happy0180: -Dennis |
#21 |
Drives: Corolla, GT86
Europe: 5 Years.
#22 |
wow you guys are getting ripped off in the states
#23 | |
Drives: GT86
I started the 86 Club for Lebanon so I've been in constant communication with the dealership here and I've raised the Oil issue with the Managing Director and the Head of After-Sales Service. They contacted Toyota Japan requesting additional information regarding the whole oil thing. Toyota Japan replied that depending on climate / humidity, local fuel quality, environmental conditions (such as dust or whatnot), etc., the Toyota engineers in Japan recommend the heavier oil for the GT86 for Lebanon. I believe it might be a similar situation in Saudi also, just wanted to let you know especially with temperatures getting as high as 60 celsius on some days. |
| The Following User Says Thank You to Froylavin For This Useful Post: | AZOOZ_95 (08-20-2013) |
#24 | |
-Dennis |
#25 |
Hail Magnet
This actually turned into a pretty interesting thread. Subbed, and good job guys.
Good luck Azooz! |
| The Following User Says Thank You to HunterGreene For This Useful Post: | AZOOZ_95 (08-20-2013) |
#26 | |
Drives: 2005 Toyota Camry
Most people would only make use of the 3 year warranty under normal circumstances. -alex |
#27 | |
EDIT: But I agree with that recommendation for heavier oil
#28 | |
Drives: GT86
I can check with him if they have the oil or ask what oil the BRZs are using. |
| The Following User Says Thank You to Froylavin For This Useful Post: | AZOOZ_95 (08-25-2013) |
| Important: DBA Rear Rotors (BRZ/FR-S) | FRS2000 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 07-17-2013 09:08 PM |
| **IMPORTANT ISSUE****READ THIS****NEED YOUR HELP** | fred864 | Issues | Warranty | Recalls / TSB | 33 | 04-20-2013 01:57 AM |
| **IMPORTANT** Sand in the engine block | USMC FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2013 08:44 PM |
| Color, how important is it to you? | Iixii | BRZ First-Gen (2012+) — General Topics | 63 | 11-09-2012 11:25 AM |
| How important is an LSD on this car? | colHolm | Scion FR-S / Toyota 86 GT86 General Forum | 92 | 05-13-2011 06:53 PM |
