Old 08-18-2013, 03:58 AM   #15
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
Thanks a lot guys , with things u guys have told me i went to the dealership, and told them that they have to provide the recommended oil for the car. Turns out they dont have the recommended oil is because they dont sell much of the gt86 here . So, they said they're going to contact there oil supplier, and see if they make it. If that doesn't work out I told what if i got the oil and u guys put it in, he agreed and said that it wont void my warranty.
AZOOZ_95 is offline   Reply With Quote
Old 08-18-2013, 12:16 PM   #16
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by zooki View Post
Well, actually a lower first number means a lower viscosity, which means a thinner oil. The oil companies add polymers that actually thicken up the oil as its gets hotter(to a certain point), which gets the oil to the last number. So a 0W20 oil will flow like a 0 weight oil at startup, and a thicker 20 weight oil when running at 100 C.
Common misconception. The oil gets thinner as it gets hotter.
The VI additives stop conventional oil from getting too thin as it heats up. Synthetic oil really doesn't rely on VI to maintain correct viscosity, the oil is assembled or refined to ensure the heavy waxy elements that cause oil to thicken when cold just aren't there. The lower W number means the oil has equivalent viscosity to a straight weight oil of that number when cold, not when hot. A zeroW (0W 20, for example) means there is no straight weight oil with that viscosity when cold.
It really matters what that W number is because that's the oil protecting your engine while it was up. VI additives were invented to protect your engine when cold, so that much lower viscosity conventional oil could be used. Conventional oil is not like synthetic. It matters which you use in some engines, such as our BRZ.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
zooki (08-19-2013)
Old 08-18-2013, 09:35 PM   #17
fledonfoot
Drives: Asphalt FR-S
Originally Posted by czar07 View Post
PS they cant void your factory warranty for getting it serviced somewhere else. They can void the dealer extended warranty though
OP is not in the US/Canada. In "small volume" countries, this can be normal.
fledonfoot is offline   Reply With Quote
Old 08-18-2013, 09:41 PM   #18
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
I assume factory warranty is the same all over the world..? Could be wrong
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 08-19-2013, 12:26 PM   #19
bluesubie
Drives: 2004 Subaru Forester 2.5XT
I keep seeing references to the first number representing viscosity when "cold". It is actually the apparent viscosity results during the Cold Cranking Simulator test at -35C for 0W oil and -30C for 5W oil which is not very relevant to the OP.
http://www.pqiamerica.com/coldcrank.htm
Unfortuntately, it's difficult to tell what the oil's actual viscosity is at a given temp like 0C or 20C. A viscosity graph does give you sort of a ball park of the actual viscosity at a given temp (although it may not be 100% accurate either). http://www.widman.biz/English/Calculators/Graph.html
Plugging in the Mobil1 N. America viscosity numbers at 40C and 100C for the 0W-20 and 0W-40, you can see that the viscosity of M1 0W-20 is 44.8 cSt's and 0W-40 is 75 cSt's at 40C/86F. As a comparison, M1 5W-20 is 49.8 and M1 5W-30 is 61.7 at the same temp. This probably represents a "cold start" for the OP.
Most 0W-x oils, regardless if conventional or "synthetic" do contain Viscosity Index Improvers. Ester based 5W oils like Red Line or Motul 300V usually contain less or no VII's, but most companies (even Red Line) need to add them to the 0W-x oils to meet the CCS spec. You can contact Red Line for details.
AZOOZ, it's good that your dealer is trying to get the right oil for you.
:happy0180:
-Dennis
bluesubie is offline   Reply With Quote
Old 08-19-2013, 01:01 PM   #20
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Warranty is never the same between countries, even from the factory.
Case in point:
US: 3 years 36000 miles
Taiwan: 3 years 100000 KM (62500 miles)
-alex
Trap63 (08-20-2013)
Old 08-19-2013, 01:03 PM   #21
Aydhayeth
Drives: Corolla, GT86
Europe: 5 Years.
Aydhayeth is offline   Reply With Quote
Old 08-20-2013, 05:06 AM   #22
czar07
czar07's Avatar
wow you guys are getting ripped off in the states
Old 08-20-2013, 07:03 AM   #23
Froylavin
Drives: GT86
Azooz! I live in Lebanon and I was facing the same problem, they were using 5W40 when the recommended oil is 0W20. I've lived in Saudi before and I know how hot it can get.
I started the 86 Club for Lebanon so I've been in constant communication with the dealership here and I've raised the Oil issue with the Managing Director and the Head of After-Sales Service.
They contacted Toyota Japan requesting additional information regarding the whole oil thing. Toyota Japan replied that depending on climate / humidity, local fuel quality, environmental conditions (such as dust or whatnot), etc., the Toyota engineers in Japan recommend the heavier oil for the GT86 for Lebanon.
I believe it might be a similar situation in Saudi also, just wanted to let you know especially with temperatures getting as high as 60 celsius on some days.
Froylavin is offline   Reply With Quote
The Following User Says Thank You to Froylavin For This Useful Post:
AZOOZ_95 (08-20-2013)
Old 08-20-2013, 09:42 AM   #24
bluesubie
Case in point:
-alex
Actually, the U.S. is 3 years/36k miles for the bumper to bumper warranty and 5 years/60k miles for the powertrain warranty.
-Dennis
Old 08-20-2013, 09:50 AM   #25
HunterGreene
Hail Magnet
HunterGreene's Avatar
This actually turned into a pretty interesting thread. Subbed, and good job guys.
Good luck Azooz!
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Old 08-20-2013, 12:44 PM   #26
mav1178
mav1178's Avatar
-Dennis
I know, I'm just stating the warranty in other countries are drastically different.
Most people would only make use of the 3 year warranty under normal circumstances.
-alex
Old 08-20-2013, 07:48 PM   #27
czar07
czar07's Avatar
Dont you guys have a Subaru dealership in Lebanon? They will MOST definitely have 0w20
EDIT: But I agree with that recommendation for heavier oil
Old 08-21-2013, 03:44 AM   #28
Froylavin
Drives: GT86
We do have a Subaru dealership in Lebanon. Actually, we merged the 86 Club into the 86 BRZ Club and we have the son of the owner of the Subaru dealership with us in the group.
I can check with him if they have the oil or ask what oil the BRZs are using.
AZOOZ_95 (08-25-2013)
Important: DBA Rear Rotors (BRZ/FR-S) FRS2000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-17-2013 09:08 PM
**IMPORTANT ISSUE****READ THIS****NEED YOUR HELP** fred864 Issues | Warranty | Recalls / TSB 33 04-20-2013 01:57 AM
**IMPORTANT** Sand in the engine block USMC FR-S Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2013 08:44 PM
Color, how important is it to you? Iixii BRZ First-Gen (2012+) — General Topics 63 11-09-2012 11:25 AM
How important is an LSD on this car? colHolm Scion FR-S / Toyota 86 GT86 General Forum 92 05-13-2011 06:53 PM
