#15 | |
#16 |
Well don't you have the stock map??
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#17 |
Drives: Scion FR-S
#18 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
wow thats bad
i was making 250 whp at 8psi with johns tune and i thought it was not good at all. talk to LJ @FullBlown he will get you a nice tune
#19 |
240@6.7 psi. It's since been cranked up though....
Sent from my iPhone using Tapatalk 2
#20 |
Drives: Scion FR-S
#21 |
I'm gonna say yes. Not 100% sure what brand Lj runs
#22 |
Drives: Scion FRS
#23 |
Love Boost!!!!!!!!
I know you will get it right
#24 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I saw your car last week while your clutch was being installed.
![]() May I ask why you just did not have him do his own custom tune? Is that a stock VS tuned turbo? or Tuned turbo VS non tuned turbo? Because if that was bone stock vs turbo that TQ is way higher than mine :P Pete's/Works dyno rates quite a bit lower than most. I think it is like 8-10% compared to my other tuner using a mustang dyno. But I really think 91 is what's killin us. wen we go FI on my girls FRS we will be going to e-85. Here is a pic of of the frs dyno with a cat back muffler and intake VS intake, boral headers, up pipe, front pipe, catback with tune. ![]() Here is a pic of the dyno from my other tuner same vs same ![]() Also I noticed you still have stock over pipe and front pipe. Changing them out may help as well. |
#25 |
He always does
#26 |
Drives: Blue Subarus
Update: Got a new map from Visconti early this morning. He wanted a pull on map 1 and 2. I drove around for a bit and got a couple pulls in on map 1, it no longer had hesitation going into boost, but was still much leaner than I'd like. Cold starting was completely resolved as well. On the previous maps the car would stall out unless you gave it constant throttle for 30 seconds.
Now the bad news...switched to map 2. I tried going into boost a couple times and noticed my AEM failsafe didn't show any AF/R readings, as if it was outside of the 10-18 range it can read. Ok..headed home to review logs. Driving on local road, 25ish mph..heard a loud POP sound. Sounded really bad. Car drove the remaining 1/4 mile home and parked the car. Waiting to hear back from John to see if there's anything horrific in the logs.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#27 | |
Definitely. I'm not looking for high power on this map, just good/safe A/Frs. I don't like seeing my A/F ratio lean out when I hit boost.
| The Following User Says Thank You to pmccut For This Useful Post: | clayrush (07-22-2013) |
#28 |
Well I hope all goes well for you. Ill try to follow you the best I can. am not sure what fi kit we are going with. But full blown was one we were leaning to. And works is where we are going to have it tuned and likely installed. I kinda like his prototype kit as well. I just wish the flex fuel kit did not cost so much.
| 86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 07:54 AM |
| Richmond VA Dyno Day Results 5/4/13 | vtmike | Engine, Exhaust, Transmission | 86 | 09-17-2013 03:34 PM |
| Interesting Dyno Results | Gen | Forced Induction | 86 | 07-31-2013 09:45 PM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Pocket Dyno App Results | CBR600RR | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 09-12-2012 11:45 PM |
