#15 |
Boosted
Drives: Not a supra....yet
The manual does have a sport mode which allows you a little less intervention from the nannies, I'd use it on canyon runs hence it does allow the tail to kick out, but would correct it if it's too much.
#16 | |
Drives: FR-S 6MT
#17 |
Ridge Racerrrrrrrrr
Yes, spinning your car badly can typically result in a stall - especially with an auto
#18 |
Drives: Whiteout Scion FR-S
I have generally experienced stalls in bad spins with several cars. I drive MT cars and usually am on the clutch and brake immediately. Still stalls. I think the sideways shock load on the engine does it, especially with stock engine mounts and suspension.
You should try and see if the "Pedal Dance" will work with an AT car. See this thread: http://www.ft86club.com/forums/showthread.php?t=25494
#19 |
Check your PCV line from intake manifold down back of motor, this blew off/got loose and caused the exact issue for a few track guys.
#20 |
Drives: On track
Seems to be an Automatic trans issue and not an issue with the car. Try driving the car up a steep hill - while you are driving up the hill, come to a complete stop, and let the car roll backwards with your foot off the brake or gas - it will likely stall (make sure the hill is steep enough to allows the car to roll back - if the car doesn't have an anti roll back feature).
It's the nature of Automatic transmissions. Sorry. |
#21 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Whichever. I just know that Autos stall out in spins much much easier than Manuals. It appears to be because the TC doesn't allow the engine to spin independent of the driveline in these situations.
#22 |
Drives: SSM LT MT BRZ
the problem is you lifted.
Stay in the throttle, drive out. |
#23 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
![]() The AT also has the VSC Sport button on the right side, but there's an additional Sport button in the middle as well (above the snow button) - it's not the same as VSC Sport. The Sport mode button in the middle just allows higher revs before gear changes - something that you'd do yourself on an MT.
#24 |
Drives: Argento FRS
| Tags |
| stall spin out drifting |
| DIY Cusco Spin Turn Knob Installation - Video Guide | Alex | DIY (Do-It-Yourself) Guides | 25 | 08-02-2015 03:03 PM |
| FS: Cusco Spin Turn Knob Drift Button in Socal | mtsui | Interior Parts (Incl. Lighting) | 4 | 06-09-2013 10:14 PM |
| Cusco Spin Turn Knob (Drift Knob) | gatorbushmen | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 04-29-2013 11:14 PM |
| AT holding 2nd gear to high revs during a long left turn | EK_Golfer | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 03-01-2013 10:35 AM |
| which spin turn knob fits the frs? | gonzo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-31-2012 07:12 PM |
