Old 05-29-2013, 01:33 PM   #15
Dezoris
Dezoris's Avatar
Originally Posted by PERRIN_Mladen View Post
All of our testing/proving has been done with the oil cooler in that position.
While this can increase the charge temperatures some amount, it's not enough to worry about.
During our dynoing, (less air flow than what we see on the road) our charge temperatures only got up to about 100F during some 13PSI runs.
I have been testing the same this past week. Oil temps and charge temps are under control with the oil cooler in front of the intercooler. I would say the oil temp plays a larger factor in performance than the charge temps.
The only issue I have with the Perrin cooler is that you guys need to design a protective grill for in front of it. I am having one custom made but it's at a prime location for damage.
Old 05-29-2013, 04:41 PM   #16
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by ft86me View Post
not at all. vortech is the company that will supply you the kit. rich and john will take your order and submit it. the rest is in the hands of vortech. rich and john have been pushing them to get things going faster, but vortech is currently backed up with all of the other orders as well replacement of older blowers. i'm not sure how i got mine in the time frame that I did, but i consider myself lucky. i just waited. that's all.
Did you get a chance to get it to a dyno yet? I know my "get it running and functional" map kicked my mpg right in the teeth, about 24mpg, had it like that for 2 days, and I was babying it. After the dyno tune the mpg is back up to 30-28.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-29-2013, 05:35 PM   #17
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
Originally Posted by Brian@Vortech View Post
Just a suggestion, but you might want to find another spot to mount the oil cooler. By placing it in front of the intercooler, you are only going to succeed in compromising the effectiveness of both units. I know the instructions on the Perrin oil cooler say to mount it in that spot, but they probably weren't thinking in terms of an intercooler being mounted directly behind it when they wrote those instructions.
I've always wondered, is there any easy way to mount the Perrin intercooler up top if you wanted to use a scoop to feed cool air to it?
Jar is offline   Reply With Quote
Old 05-30-2013, 12:13 AM   #18
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
I agree we tested it already on the track with the oil cooler on the front does not effect the temperatures at all.
Evasive Motorsports is offline   Reply With Quote
Old 05-30-2013, 10:13 PM   #19
ft86me
ft86me's Avatar
Drives: 2013 FRS
i have not yet. i'm thinking about doing it in about two to three weeks. i have family from japan over right now so that comes first. after that, i'll be heading to the dyno and posting some goodies. hoping for some good numbers.
my mpg is currently at 22.9 but you can probably guess why hahahaha. 1. i love hearing it spool . 2. i love hearing the bpv 3. i love the power = bye bye fuel haha
ft86me is offline   Reply With Quote
Old 08-23-2013, 09:10 PM   #20
NCItaly
Drives: 2013 BRZ Limited
how bout that dyno?
Sent from my RM-820_nam_att_100 using Tapatalk
NCItaly is offline   Reply With Quote
Old 08-24-2013, 03:57 AM   #21
foursix86
Drives: 13 FR-S
A larger capacity oil pan (~8 qts.) would negate the need for an oil cooler on most applications.
foursix86 is offline   Reply With Quote
Old 08-24-2013, 10:54 AM   #22
Adeets
OEDC
Adeets's Avatar
Originally Posted by NCItaly View Post
how bout that dyno?
If he got ahold of visconti right before the fire it is prolly pushing 250-260, if he's still using the same tune he started with its between 230-240. Or maybe hes gone with a different tuner because his honey moon is over with visconti and he realizes his car isn't in safe hands... Then he's prolly making 260+ with out over reving the engine.
My BRZ FI Build
Old 08-24-2013, 12:52 PM   #23
nonicname
Drives: it has 4 wheels and a motor
glad to see it didn't catch on fire
nonicname is offline   Reply With Quote
Old 08-24-2013, 01:01 PM   #24
Mikem53
Drives: FR-S 6MT
Disagree here..
Intake air temps would make more of a performance factor than oil temps..
You want a hot engine and cool intake air for optimal engine output.
Oil temps need to be in check for reliablity.. Cooler intake air allows more fuel to
Be added for more power.. And helps keep keeps detonation in check
Mikem53 is offline   Reply With Quote
Old 08-24-2013, 07:15 PM   #25
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Who are you using? What are your mods?
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 08-24-2013, 07:38 PM   #26
Dezoris
Dezoris's Avatar
Originally Posted by Mikem53 View Post
Disagree here..
I was referring to the Vortech kit with perrin oil cooler. Oil temps effected my setup more than charge temps in my case on the track.
Old 08-24-2013, 09:20 PM   #27
DJCarbine
Thupercharged
DJCarbine's Avatar
Did you notice any ignition timing being pulled/extra fuel added when oil temps got to a certain threshold?
2013 FRS
Vortech V3 11psi
Old 08-24-2013, 09:40 PM   #28
Dezoris
Dezoris's Avatar
On track timing reduced -1.
Vortech Visconti Tuned on BRZ Limited v1ru5 Member's Car Journals 85 01-08-2015 01:09 PM
FR-S driver01 Forced Induction 78 07-04-2013 10:07 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
