Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#15 | |
Drives: 2013 Black FR-S
Take major FI bits off. Bolt on stock headers and intake and emissions equip. Leave the bigger injectors in there. Flash an NA tune for the bigger injectors (so you don't run super rich) Would this work? |
#16 |
Drives: 2015 Mustang GT (on order)
I'll break this down simply:
California does visual inspection, OBD scanning, and tail pipe (sniffer) testing. - For visual inspection, you cannot modify anything in the intake tract unless it has a CARB exemption. Intakes sold with CARB exemption will be labeled as such and have a sticker on them that the smog tech can read. You cannot touch anything in the exhaust from the header, up to and including the second cat unless those parts have a CARB exemption as well. In a decade or so, you will find some aftermarket cats with CARB approval, but up until the 8 year emissions period, no aftermarket cat will be legal to use. A turbo kit with a CARB exemption will retain all emissions equipment...and I have yet to see a kit out that does that. It might happen..don't hold your breath. You can do whatever you want after the second cat. Even a straight pipe...totally legal as far as smog goes. However, if it's over 95db you can get a ticket from the police for it. - For the OBD scan your car must be done with all its readiness monitors (this means you can't just reset the ECU right before going in for a smog...generally it takes 25-200 miles of driving). Your car cannot have any emissions related codes either. If you have a tune, the OBD scan will not detect it. If your tune disables codes for cat efficiency, etc; the OBD scan will not detect it. - The sniffer is pretty self explanatory. Can you cheat these tests? The answer is yes. But it's getting harder and harder. Some techs don't know exactly what they are looking for so you might be able to sneak past the visual. I have done this with a car running a JDM header that had a heatshield that looked OEM. As I mentioned above, you can sneak past the OBD portion with the right tune in place. You will not be able to sneak past the sniffer though. So if you are running non CARB parts and a custom tune, you better hope the car still farts nice and clean.
The Following 4 Users Say Thank You to jeebus For This Useful Post: |
#17 | |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
#18 |
Spun
Drives: 17' Focus RS
Cali is brutal. Time to move or overthrow your local government.
The Following 2 Users Say Thank You to Timmy_Jones For This Useful Post: | CA2 (04-24-2013), Tim_Asphalt_FRS (04-24-2013) |
#19 |
Drives: Scion FR-S
California no longer does sniffer on new cars, btw.
Visual and plug-in only. It's a money grab imo. The only thing they should be doing is sniffer. |
The Following 5 Users Say Thank You to Gen For This Useful Post: | Bonburner (04-23-2013), CA2 (04-24-2013), N8RH8R (03-29-2018), siXXtoes (04-24-2013), Tim_Asphalt_FRS (04-24-2013) |
#20 |
Drives: car
On new cars, the OBD system is better at judging an emissions problem than the simplistic steady-state tailpipe tests anyway. From the perspective of CARB, it makes sense. It saves the shops time and doesn't hurt CARB's agenda.
#21 | |
#22 | |
Drives: Scion FR-S
http://www.smogtips.com/new-smog-law-AB-2289.cfm "Set to begin January 01, 2013; Model year 2000 and newer vehicles will no longer require the tailpipe emissions test portion of the smog check process. AB 2289 will require late model vehicles be administered the smog check's visual and functional tests only." |
#23 |
Proud of BOXER
Drives: Subaru Boxer
I'm not sure places are actually following this. I got my 2007 Scion tC smogged in March and they still put a sniffer in the pipe.
#24 |
Drives: Your Car
If we were to run aftermarket headers and got pulled over, is that a ticket for messing with the cats or a simple fix it?
Sent from my SGH-I777 using Tapatalk 2
#25 | |
86 Noob
Drives: Firestorm FR-S
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
#26 |
Drives: Scion FR-S
To be honest, I don't think a cop would be able to tell. There is still a cat underneath the car. It's a fine, but I believe significantly less than if you were to remove BOTH cats.
#27 | |
$2500 fine. Only certain cops have the certifications that qualify them to ticket you for it, however if they are suspicious they can call someone out that has those certs.
The Following User Says Thank You to jeebus For This Useful Post: | bdanisi (04-24-2013) |
#28 |
You Made Bro?
Drives: Raven 86
2500 bucks. Lol. I'll wait for some catted headers. How about a high flow catted front pipe? Would I be ok if I bought catted headers and a high flow catted front pipe, would that set up get me into trouble?
Emissions question with a ecu flash | sw20kosh | Engine, Exhaust, Transmission | 2 | 04-08-2013 01:11 AM |
CA emissions ECU flash recall? | icemang17 | Issues | Warranty | Recalls / TSB | 1 | 04-05-2013 07:46 PM |
Massachusetts Emissions | ngabdala | New England | 3 | 11-26-2012 07:25 AM |
Question about smog checks/emissions | showbe | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 09-28-2012 12:03 AM |
Can the new emissions standards for 2011 alter the ft-86 | 2jz-gte4life | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 04-05-2010 01:16 AM |
