Old 12-06-2012, 08:18 PM   #15
j.t.
I always thought the wind noise was due to the large side mirrors and the channel of air they create between them and the window.
j.t. is offline   Reply With Quote
Old 12-06-2012, 09:21 PM   #16
Razz
Razz's Avatar
Drives: Fast
There are several people with the same complaint on the FRS.
Have your dealer adjust the window.
Razz is offline   Reply With Quote
Old 12-06-2012, 09:54 PM   #17
BRZnut
Drives: BRZ DGM Limited
I'm always afraid to have the dealer touch my car unless I can show them exactly what is wrong. I could see them adjust the window and make it worse. Just paranoid I guess! I'm starting to think the sound is coming from that small window on the passanger side door.
Old 12-06-2012, 10:02 PM   #18
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Mine is quiet so far, only 800 miles though. Most quiet out of all the Subaru's I have owned.
Jaylyons1 is offline   Reply With Quote
Old 06-11-2013, 06:14 PM   #19
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
UPDATE: So I finally got the weatherstripping replaced by Subaru after complaining about it twice. The wind noise I was experiencing was like your window is down a crack (abnormal) vs the sound of wind actually hitting the window (apparently normal).
The tech showed me the old weather stripping and how it did have a crack lengthwise where the two points of plastic/rubber are melted together.
Now after the replacement, The wind noise is 80%-90% improved. Still has the "air hitting the window" noise at high speeds but not the window being down a crack noise.
Id suggest the best way to tell is to compare passenger vs drivers side wind noise. Mine was noticeably worse on the drivers side
Very glad I had it changed. Total install time took them 45-60 minutes.
side note: They did insist to me multiple times that what I was hearing was normal (even with ride alongs) so dont be afraid to be persistent if you feel its an issue.
Side note #2: That small cracking of the plastic on the superior surface of the triangle portion of the window that does not roll down was not changed and still has the crack. But this had no effect on the wind noise improvement.
2013 Subaru BRZ - SWP - 6MT
ShoGun is offline   Reply With Quote
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
Excessive smoking from left exhaust? Derrick Issues | Warranty | Recalls / TSB 3 11-25-2012 07:37 AM
Wind noise at 65 mph? Siamtampa Scion FR-S / Toyota 86 GT86 General Forum 33 07-31-2012 01:47 AM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
Excessive wheel weights? muffinman Other Vehicles & General Automotive Discussions 6 05-25-2012 09:59 AM
