#15 |
Drives: '22 BRZ
This is relevant because reasons:
Needed more rear camber! Rear lower control arms from the first gen aren't legal on the new car due to a change in motion ratio, makes this mildly annoying but oh well. The only other options are a $650 set of upper control arms or a $130 set of offset upper arm bushings that are a huge PITA to install and adjust as well as being easy to have them slip... I'm giving a $25 option a try I got ~0.3 degrees more rear camber (one side gained like 0.5 degrees, so I just evened it out) using two MOOG K90473 camber bolts. They torque to about the same torque spec as the OEM bolts so I'm hoping they don't slip. I'll find out soon!![]() ![]() Alignment before: ![]() Alignment after:
| The Following User Says Thank You to DocWalt For This Useful Post: | Simmons (05-08-2022) |
#16 |
Drives: 2017 BRZ series.yellow
Maybe I'm on the outskirts... but that doesn't seem like a good idea to me. The place that bolt is meant for is under very different stresses.
#17 | |
Drives: '22 BRZ
I'll be keeping an eye on it, but other folks have had good success: https://www.ft86club.com/forums/showthread.php?t=33415
#18 |
Drives: '22 BRZ
Did NNJR event 3 today, got the car working well finally (hey guess what, setting the shocks to where Shaftworks told me to set them works well) and Evan Schickel, 2018 DSP national champion, codrove to get ready for the NJ ProSolo
My fastest, good for 2nd in PAX, very close to Jeff Hurst (2013 STX national champion) in an STR ND: Evan's fastest scratch time: and a wild side by side!
| The Following User Says Thank You to DocWalt For This Useful Post: | steverife (05-14-2022) |
#19 |
Drives: 2016 Scion FRS
I'm bummed that I didn't get to watch any of these at Charlotte. I watched some of the DS cars, but I found them to appear not relevant to my interests.
#20 | |
Drives: '22 BRZ
I've yet to drive one in DS trim, but in STR it's a TON of fun. Seems to be at least reasonably competitive with the ND, though definitely lacking. A tune will help, but I think it would need to gain 25whp to be super relevant in STR at the top. Definitely good enough to trophy with at nats though as it is, based on the performance of our STR Twin guys locally.
#21 | |
| The Following User Says Thank You to steverife For This Useful Post: | DocWalt (05-19-2022) |
#22 | |
Drives: LP DSP / CSP '13 BRZ
Totally anecdotal but launching next to a STR GR86 at practice starts in Charlotte, a STR 86 and a DSP 1st Gen get to the 120' mark at pretty much the same time. |
#23 |
Drives: 2024 GR86/ 2015 FRS
At Zmax pro I was getting 2.1 60ft and 4.6 to 200ft.
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#24 | |
Drives: '22 BRZ
LOL. Like some RX-8 folks...
#25 | |
Drives: 2022 BRZ; 2014 BRZ
#26 | |
Custom User Title
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#27 |
Drives: Miata
Hard to make up for 400+ lbs.
#28 | |
Drives: '22 BRZ
After NJ Pro... I still disagree with you. New twin can trophy in STR. Did I execute it well enough? No. Will it be a lot of the same folks running STR at nats that beat us in the twins? Yes... Just with more people so there are more trophies. So I think it will be easy for a twin to trophy in STR? Hell no. Do I think the ND should probably have its own class and put STR back to how it was before 2016 just with the new twins added? Hell yes.
| 2022 Twin to STR | Simmons | BRZ Second-Gen (2022+) — General Topics | 11 | 03-01-2022 11:03 AM |
| 2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition | Hachiroku | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 13 | 02-13-2022 12:44 AM |
| 2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition | Hachiroku | BRZ Second-Gen (2022+) — General Topics | 20 | 02-10-2022 12:44 PM |
| 2022 Toyota Land Cruiser Revealed With New Platform, Twin-Turbo V6 | vh_supra26 | Other Vehicles & General Automotive Discussions | 24 | 07-07-2021 02:44 PM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 03:36 PM |
