Old 05-05-2022, 12:04 PM   #15
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
This is relevant because reasons:
Needed more rear camber! Rear lower control arms from the first gen aren't legal on the new car due to a change in motion ratio, makes this mildly annoying but oh well. The only other options are a $650 set of upper control arms or a $130 set of offset upper arm bushings that are a huge PITA to install and adjust as well as being easy to have them slip...
I'm giving a $25 option a try I got ~0.3 degrees more rear camber (one side gained like 0.5 degrees, so I just evened it out) using two MOOG K90473 camber bolts. They torque to about the same torque spec as the OEM bolts so I'm hoping they don't slip. I'll find out soon!
Alignment before:
Alignment after:
The Following User Says Thank You to DocWalt For This Useful Post:
Simmons (05-08-2022)
Old 05-05-2022, 07:13 PM   #16
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Maybe I'm on the outskirts... but that doesn't seem like a good idea to me. The place that bolt is meant for is under very different stresses.
Breezio is offline   Reply With Quote
Old 05-06-2022, 10:01 AM   #17
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'll be keeping an eye on it, but other folks have had good success: https://www.ft86club.com/forums/showthread.php?t=33415
Old 05-14-2022, 08:29 PM   #18
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Did NNJR event 3 today, got the car working well finally (hey guess what, setting the shocks to where Shaftworks told me to set them works well) and Evan Schickel, 2018 DSP national champion, codrove to get ready for the NJ ProSolo
My fastest, good for 2nd in PAX, very close to Jeff Hurst (2013 STX national champion) in an STR ND:
Evan's fastest scratch time:
and a wild side by side!
steverife (05-14-2022)
Old 05-14-2022, 08:40 PM   #19
steverife
Drives: 2016 Scion FRS
I'm bummed that I didn't get to watch any of these at Charlotte. I watched some of the DS cars, but I found them to appear not relevant to my interests.
steverife is offline   Reply With Quote
Old 05-17-2022, 12:03 AM   #20
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I've yet to drive one in DS trim, but in STR it's a TON of fun. Seems to be at least reasonably competitive with the ND, though definitely lacking. A tune will help, but I think it would need to gain 25whp to be super relevant in STR at the top. Definitely good enough to trophy with at nats though as it is, based on the performance of our STR Twin guys locally.
Old 05-17-2022, 06:41 AM   #21
steverife
Even if the tune doesn't get you 25whp, the Mazda people will assure you that it is there and just hiding from your particular dyno.
The Following User Says Thank You to steverife For This Useful Post:
DocWalt (05-19-2022)
Old 05-17-2022, 03:17 PM   #22
Eric1855
Drives: LP DSP / CSP '13 BRZ
LOL...this
Totally anecdotal but launching next to a STR GR86 at practice starts in Charlotte, a STR 86 and a DSP 1st Gen get to the 120' mark at pretty much the same time.
Eric1855 is offline   Reply With Quote
Old 05-17-2022, 11:05 PM   #23
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by Eric1855 View Post
LOL...this
At Zmax pro I was getting 2.1 60ft and 4.6 to 200ft.
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 05-19-2022, 01:41 PM   #24
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
LOL. Like some RX-8 folks...
Old 05-19-2022, 02:06 PM   #25
foshjowler
Drives: 2022 BRZ; 2014 BRZ
I'd be surprised if any of the new twins get a trophy in STR this year at nats. Watching them at Charlotte, it was quite clear the ND2 has a significant upper hand. In DS trim, it seems to be up in the air and course dependent as to if the twins or Type R is faster. In Charlotte, there were 3 of us before the first Type R.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
Old 05-19-2022, 04:59 PM   #26
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Watching at Crow's I can't see any way they will compete in STR at Nats. Those courses were fast and flowing if they can't excel there over the ND they're not going to at slightly tighter courses.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 05-19-2022, 07:36 PM   #27
racingfool
racingfool's Avatar
Drives: Miata
Hard to make up for 400+ lbs.
racingfool is offline   Reply With Quote
The Following 2 Users Say Thank You to racingfool For This Useful Post:
DocWalt (05-23-2022), Simmons (05-22-2022)
Old 05-23-2022, 01:07 PM   #28
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
After NJ Pro... I still disagree with you. New twin can trophy in STR.
Did I execute it well enough? No. Will it be a lot of the same folks running STR at nats that beat us in the twins? Yes... Just with more people so there are more trophies.
So I think it will be easy for a twin to trophy in STR? Hell no. Do I think the ND should probably have its own class and put STR back to how it was before 2016 just with the new twins added? Hell yes.
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
des (05-23-2022), e1_griego (05-23-2022), Kelse92 (05-23-2022)
2022 Twin to STR Simmons BRZ Second-Gen (2022+) — General Topics 11 03-01-2022 10:03 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-12-2022 11:44 PM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) — General Topics 20 02-10-2022 11:44 AM
2022 Toyota Land Cruiser Revealed With New Platform, Twin-Turbo V6 vh_supra26 Other Vehicles & General Automotive Discussions 24 07-07-2021 01:44 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
