Old 05-05-2020, 07:52 PM   #15
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Also, you never actually said if this issue started only after the radiator and thermostat got replaced. Is that the case? Because all of our replies assume you didn't already have this issue.
Just want to clarify.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 05-06-2020, 04:12 PM   #16
Andrei
Drives: Leon4x4 PRECISION6466,buyng soonBRZ
Originally Posted by RZNT4R View Post
So I am to presume that when the fans kick in high, it's blowing out a LOT of VERY HOT air? I've seen low circulating systems where the rad gets hot, but as soon as the fans kick in they drain all the heat out of it and blow cold air as the engine keeps getting hotter and hotter.
Thermostats typically don't fit in backwards.
When the car is on idle it didn't spill water or overheat
Originally Posted by Grady View Post
You changed the radiator and now you have a problem????
Step one, take everything off that you just put on. (paying attention to how it was installed)
Step two, read manual on how to assemble.
Step three, assemble the correct way.
Step four, drink beer and pat yourself on the back for a job well done!
I had a little leak (visible) on the older radiator for a year, but it got worse at once and I changed to a new one.
I changed it in a very good shop and I was checking all the process and the job was done well
and sorry, I don't drink beer
I first notice it 2 road trips after the radiator changed (I don't use my BRZ as a daily), I am not sure if the problem started right away, I actually think that the older radiator broke because it was the "weak link" because the high pressure in the system, and now it goes to the cap.
so I tried to change the thermostat to a new one and still the same problem
My guess that is head gasket failure, my car had not very long ago a bad direct injector, maybe he made the damage ( https://www.ft86club.com/forums/show...49#post3287349)
I just want to be sure that is the head gasket before I take apart the motor and I don't find a way to be sure
Andrei is offline   Reply With Quote
Old 05-06-2020, 06:00 PM   #17
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
There is a way to be sure of a head gasket.
What you will need is an compression test gauge with the appropriate adaptor for the fa20's spark plug threads, an air compressor, a big ratchet to turn the engine over by hand from the crank pulley, some other basic tools and lots of patience given the accessibility of the plugs on this engine.
Here is what you will need to do:
- Take all the spark plugs out
- Remove the Schrader valve from the compression tester hose so you can send air into the engine.
- Install the compression test hose into the first cylinder
- Remove the radiator cap and level the fluid so its half way down the filler neck
- Install the air compressor onto the compression test hose, sending high pressure air (ideally 120+ Psi) into the cylinder
- Rotate the engine by hand with your big ratchet on the crank pulley until the pressurized cylinder enters the compression stroke and the valves shut. It will immediately refuse to turn any further.
And now, as you strain against the ratchet to keep the engine from turning backwards, watch the coolant level closely. Hold it for at least 30 seconds. If the coolant level rises or overflows, that's your bad gasket.
Do all 4 cylinders. If none make it throw up coolant, it's highly u likely you've got a bad head gasket.
The Following User Says Thank You to RZNT4R For This Useful Post:
Ultramaroon (05-06-2020)
Old 05-06-2020, 08:03 PM   #18
ActionMaxon
If you proceed with RZNT4R's recommendation, I would suggest starting with the cylinder that you had the bad injector. If it was causing a lean condition, that could produce the kind of excessive heat that leads to head gasket failure.
2016 Oceanic
Old 10-06-2020, 10:47 AM   #19
Andrei
sorry I forgot to update,
It was head gasket leak, seems more of a problem that the head bolts
were stretched (was very easy to open) then the head gasket problem.
I recommend to put ARP ones if your gonna do a head gasket change
The Following User Says Thank You to Andrei For This Useful Post:
bcj (10-06-2020)
presure
Cooling System Not Holding Fluid romendiratta Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-03-2020 09:20 PM
Overheating / Cooling System Basics Rennmeister Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 11-08-2017 05:16 PM
Which part of the cooling system is this from? texasbound972 Engine, Exhaust, Transmission 9 04-12-2016 02:47 AM
No a/c but system has pressure ZionsWrath Other Vehicles & General Automotive Discussions 8 06-14-2015 02:43 PM
Bleed air from radiator/cooling system? OnionTou Engine, Exhaust, Transmission 2 03-28-2014 08:54 PM
