Old 04-03-2020, 08:29 PM   #1
romendiratta
Drives: White Scion FRS
Cooling System Not Holding Fluid
Hey Everyone,
Im pretty new to all of this, and I was attempting to do a coolant change on my car. I removed the plastic drain plug on the bottom and drained all of the fluid, but after I have put the plug back in and tried to refill it, all of the fluid is flowing out. Specifically it is coming out from the valve right above the plastic drain plug. Am I missing something? And thanks in advance.
romendiratta is offline   Reply With Quote
Old 04-03-2020, 09:38 PM   #2
alan.chalkley
Drives: 4wd zooks
Do an air pressure (pump test) and see where the air is escaping.
alan.chalkley is offline   Reply With Quote
Old 04-03-2020, 10:00 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Ok. Odd that you wanted to change the coolant. If you saw that the coolant level was just low just keep adding a cup of coolant. It's kind of normal to lose a cup every season.
Just in case there is a proper way to "bleed" the coolant system. Why you didn't download the repair manual or YouTube/google it, is all on you.
Old 04-03-2020, 10:20 PM   #4
romendiratta
Apparently there was a contaminant in the system that was degrading the rubber, so I needed to do a full flush. Also if turned out that there was a missing o-ring on the drain plug, so the valve above was not sealing. Thanks for the help though!
cooling, drain plug, leak, radiator
Windshield fluid pump system - check valve failed zeroxg35 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-25-2018 12:47 PM
Overheating / Cooling System Basics Rennmeister Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 11-08-2017 06:16 PM
Which part of the cooling system is this from? texasbound972 Engine, Exhaust, Transmission 9 04-12-2016 03:47 AM
Clutch system/MC fluid capacity? ZionsWrath Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-08-2014 09:40 PM
Bleed air from radiator/cooling system? OnionTou Engine, Exhaust, Transmission 2 03-28-2014 09:54 PM
