Old 05-03-2020, 06:36 PM   #15
abn
Drives: 2017 Toyota 86
I just opened the engine fuse box and noticed there are missing fuses in the car, anyone know which fuses is linked to the HAC?
abn is offline   Reply With Quote
Old 05-03-2020, 06:48 PM   #16
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
None, it exists as software in the stability control system.
Old 05-03-2020, 07:20 PM   #17
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by abn View Post
The feature is for my girlfriend, trying to learn how to drive stick shift.
seems like she could teach you some things!
Old 05-03-2020, 07:45 PM   #18
abn
Does that mean software in my car, isnt working?
Old 05-03-2020, 07:57 PM   #19
RZNT4R
If there is no abs or esp warning light lit, if the hill start assist light is on, the system should be working, unless you've got a super rare software issue no one has ever heard of.
Old 05-03-2020, 08:11 PM   #20
abn
I am not sure theres no lights on except for hill assist light. I bought the car from someone else and its a salvage title?
Could issue be the floor i turned on the hill assist was not “flat” enough?
Old 05-03-2020, 08:51 PM   #21
RZNT4R
Look, I just went out, enabled it on my car and went for a test drive.
Little green car on a hill top left of the dash, no other warning lights.
Hold the brake on a hill and let go? you roll down the hill. Holding the brake, press in the clutch, little green car starts to blink fast, you are now held on the hill, release the brake, select first, and off you go.
I don't know how much the the level, or lack thereof, of the car affect the system if you enable it while parked on a hill, I enabled mine in my parking spot, on level ground.
The Following 3 Users Say Thank You to RZNT4R For This Useful Post:
humfrz (05-03-2020), NaturallyAspirated (05-03-2020), spike021 (05-03-2020)
Old 05-03-2020, 10:20 PM   #22
humfrz
Well now, THAT was right nice of you -
Old 05-03-2020, 10:30 PM   #23
RZNT4R
Thinking further,
If the light is on and it isnt engaging, it may just lack the trigger to engage... your car starts, so we know the clutch switch works. That leaves only the brake switch.
Check that the stop lamps illuminate correctly.
Old 05-04-2020, 12:37 AM   #24
abn
Thinking further,
The stop lamps are working! Im gonna try it on a steeper hill later today
Old 05-04-2020, 12:38 AM   #25
abn
I appreciate you doing that for me. I turned it on in my garage on a level floor. Ima try ot on a steepeer hill later
Old 05-04-2020, 01:59 AM   #26
abn
I just wanted to update! It worked only a steeper hill. Strange how it didnt work on my drive way or another hill or a speed bump that always activates on my wrx. But did work on a very steep hill
Old 05-04-2020, 04:49 AM   #27
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Interesting, the green car icon doesn't blink on my Series.Yellow BRZ, but the feature still works on steeper hills.
I wonder if there's a difference between Toyota and Subaru in that regard.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 05-04-2020, 05:18 AM   #28
spike021
spike021's Avatar
Same here, no blinking.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Hill Start Assist? Watch Me Run Scion FR-S / Toyota 86 GT86 General Forum 120 10-15-2019 07:31 PM
Hill Start Assist? olivialees12 Scion FR-S / Toyota 86 GT86 General Forum 9 07-21-2018 09:49 PM
Hill start assist can’t disable Rai-zero Issues | Warranty | Recalls / TSB 23 05-24-2018 01:22 PM
Toyota 86 2017 special edition HAC (Hill Assist Control) milkydude12 Scion FR-S / Toyota 86 GT86 General Forum 32 12-13-2017 12:10 AM
Anyone planning HAC (Hill Assist) retrofit? Zardoman Engine, Exhaust, Transmission 28 06-07-2017 12:52 AM
