Old 05-23-2018, 10:19 AM   #1
Rai-zero
Drives: Legacy
Hill start assist can’t disable
I have a 2018 BRZ and I wanted to check out the hill assist feature. I turned it on, but now I don’t care for it. It’ll cause me to stall if I give it too little gas which I’m used to doing.
Anyway I did the same thing that turned it on, hold the left trac control button for around one minute until both lights go off, then let go and re press the button. Should disable the hill start but it doesn’t. What am I doing wrong?
Rai-zero is offline   Reply With Quote
Old 05-23-2018, 10:22 AM   #2
StraightOuttaCanadaEh
Wes
Just unplug the battery and that'll take care of it
Instagram: @gt86ws
Old 05-23-2018, 10:29 AM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
If I were him, I would much prefer to do it the proper way, rather than disconnecting the battery, which resets a lot of other things too...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-23-2018, 10:32 AM   #4
Old 05-23-2018, 11:05 AM   #5
extrashaky
Drives: 2014 BRZ Limited
(Image deleted)
I was curious, so I went to see what that manual said. It says to do exactly what Rai-zero says he already did:
To disable the hill start assist system, perform the above Step 1 through Step 6 again.
Old 05-23-2018, 11:12 AM   #6
extrashaky
The steps in the book also specify that you have to engage the parking brake, turn the engine off, then crank it to restart, then do the thing with the button, then turn the engine off again and crank it one last time to see that the status had changed. Did you do all that starting and stopping of the engine, or just try to do the part with the buttons?
Old 05-23-2018, 11:13 AM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
Ooops, I mean automatic***
Old 05-23-2018, 11:31 AM   #8
Rai-zero
Drives: Legacy
I did all that.
Why the hell cant Subaru just have a menu option to turn it on/of or another button like under the odometer reset?
BTW I’m sorry I even tried the feature.
Old 05-23-2018, 11:45 AM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
I feel your pain bro
I am shopping to replace my daily driver and all these newish cars have retarded "safety" crap that you can't easily or even fully turn off. So sad. I guess I should be grateful that I still have the freedom to own and commute in my own vehicle. But I'm not happy with the state of government regulation of cars "in the name of safety". Giving up freedom out of fear leads to slavery IMO.
Sorry I got carried away lol
Old 05-23-2018, 11:48 AM   #10
Wes
I think it's just the clock lol
Instagram: @gt86ws
Old 05-23-2018, 11:48 AM   #11
extrashaky
I did all that.
I'd pop into the dealer, tell them it won't turn off and get them to turn it off using the diagnostic system. If it's truly not responding to the procedure in the manual, they should do it for free under warranty.
Old 05-23-2018, 12:02 PM   #12
Stang70Fastback
A.K.A. Starlord
It's the clock. And the ECU, which leads to a floppy gas pedal until the ECU re-learns it. And it resets the gear indicator. And it causes the head unit in my 2015 to re-initialize, and go through some basic settings again...
So actually quite a few things.
Old 05-23-2018, 05:25 PM   #13
Rai-zero
Drives: Legacy
Hey guys, I figured it out, was not pressing the button in the correct time.
All good.
I feel like the assist was/could be worthwhile but in some instances such as when I am backing out of a spot or into my driveway after a stop, that I don't think it's there so if I give it light throttle the car will stall.
I think it's both good and bad at the same time, so I think I'll leave it off as that's what I've been accustom to driving since 1988.
Old 05-23-2018, 05:34 PM   #14
TheRoops
Drives: 2015 Subaru BRZ Series.Blue
Only pansies buy the strategy guide.
TheRoops is offline   Reply With Quote
Disable high Rev cold start Raven604 Engine, Exhaust, Transmission 408 03-28-2022 10:27 AM
Hill Start Assist? Watch Me Run Scion FR-S / Toyota 86 GT86 General Forum 120 10-15-2019 06:31 PM
Toyota 86 2017 special edition HAC (Hill Assist Control) milkydude12 Scion FR-S / Toyota 86 GT86 General Forum 32 12-12-2017 11:10 PM
Anyone planning HAC (Hill Assist) retrofit? Zardoman Engine, Exhaust, Transmission 28 06-06-2017 11:52 PM
Question regarding Hill-start assist control rkaywhodat Scion FR-S / Toyota 86 GT86 General Forum 17 09-30-2016 05:47 AM
