#15 |
Drives: 2017 Toyota 86
I just opened the engine fuse box and noticed there are missing fuses in the car, anyone know which fuses is linked to the HAC?
#16 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
None, it exists as software in the stability control system.
#17 |
ProCrastinationConsultant
seems like she could teach you some things!
#18 |
#19 |
#20 | |
Could issue be the floor i turned on the hill assist was not “flat” enough? |
#21 |
Look, I just went out, enabled it on my car and went for a test drive.
Little green car on a hill top left of the dash, no other warning lights. ![]() Hold the brake on a hill and let go? you roll down the hill. Holding the brake, press in the clutch, little green car starts to blink fast, you are now held on the hill, release the brake, select first, and off you go. I don't know how much the the level, or lack thereof, of the car affect the system if you enable it while parked on a hill, I enabled mine in my parking spot, on level ground. |
| The Following 3 Users Say Thank You to RZNT4R For This Useful Post: |
#22 |
#23 |
Thinking further,
If the light is on and it isnt engaging, it may just lack the trigger to engage... your car starts, so we know the clutch switch works. That leaves only the brake switch. Check that the stop lamps illuminate correctly. |
#24 |
The stop lamps are working! Im gonna try it on a steeper hill later today
#25 | |
I appreciate you doing that for me. I turned it on in my garage on a level floor. Ima try ot on a steepeer hill later |
#26 |
I just wanted to update! It worked only a steeper hill. Strange how it didnt work on my drive way or another hill or a speed bump that always activates on my wrx. But did work on a very steep hill
#27 | |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
I wonder if there's a difference between Toyota and Subaru in that regard.
#28 | ||
Instagram: @spike.grc
| Hill Start Assist? | Watch Me Run | Scion FR-S / Toyota 86 GT86 General Forum | 120 | 10-15-2019 06:31 PM |
| Hill Start Assist? | olivialees12 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 07-21-2018 08:49 PM |
| Hill start assist can’t disable | Rai-zero | Issues | Warranty | Recalls / TSB | 23 | 05-24-2018 12:22 PM |
| Toyota 86 2017 special edition HAC (Hill Assist Control) | milkydude12 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 12-12-2017 11:10 PM |
| Anyone planning HAC (Hill Assist) retrofit? | Zardoman | Engine, Exhaust, Transmission | 28 | 06-06-2017 11:52 PM |
