#15 | |
Wheels for Brains
If you want to inspect the pads: undo the caliper guide pin and spin the caliper body away from the bracket. You can also peer into the channels of the caliper body. Hard to say anything about your rotors or pads without pictures. Could be glazing. You'll have to spin the caliper if you want to pull the pads and inspect the surfaces Rotor scoring can be normal depending on the extent. |
#16 |
Wow, I can't believe you need to remove calipers just to inspect the pad thickness.
Every other car I've owned, the pads are in plain view. |
#17 | |
Drives: 2017 Subaru BRZ Limited
Unless every vehicle you had before had pinned pads (Brembos or simlar), you would need to have removed the caliper to get a good reading. You can visually inspect without removing the caliper, but that doesn't really tell you much other than a broad answer. |
#18 |
Drives: Crapcan
You could always just stick your phone down under the front of the caliper to take a picture. I can see the stock rears just fine with the wheel on.
| Clutch fluid won't bleed. | ML | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 09-19-2018 09:35 AM |
| DIY : How to bleed your brakes | justinco | DIY (Do-It-Yourself) Guides | 4 | 09-05-2017 03:40 PM |
| How often do i need to change/bleed brake fluid (DoT 5.1) | dejxx | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 07-15-2015 12:50 PM |
| Innovate Stage 2 intercooler bleed | bakilman | Forced Induction | 4 | 06-13-2014 03:48 PM |
| Bleed air from radiator/cooling system? | OnionTou | Engine, Exhaust, Transmission | 2 | 03-28-2014 09:54 PM |
