#15 | |
Benz Tech
Drives: 2017 BRZ Premium
You have a 2” discrepancy front to rear, 25” to 27”. That’s a tall tall tire on the back, front is about stock. 245/35R18 front, 285/30R18 would get you back in the game, and back to stock height. If you would like to stick with a 285 out back. Last edited by maslin; 06-02-2019 at 12:52 AM. |
#16 | |
I Love custom Turbo kits
Drives: Limited BRZ
Any of the ones in green.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Celigts (06-03-2019) |
#17 | |
Drives: 2014 Toyota FRS
Would look really funky as the rear widebody is supposed to be larger looking...
#18 |
I doubt i can get a 245/45/18 in there on the front. It already is paper thin close to rubbing ![]() What if I brought the rears down to 285/35/18? Would be a 3.6% difference from front/back. Still I'd have Wheel speed sensor issues? |
#19 |
Drives: Limited BRZ
I don't know what is the threshold for WSS to be fussing..... I personally wouldn't chance it at anything over 1.5% unless you can get proof from someone else that is known to have 3.6%+ difference and have been fine. I have only run a 1.2% difference and it was fine.
#20 | |
#21 | |
Benz Tech
Aspect ratio is the sidewall height as a percentage of the width. A wider tire with a smaller aspect ratio isn't necessarily shorter. 245/35 and 285/30 are nearly identical in height. If you want the t bucket Mickey Thompson look you're going to need a car without fancy electronics. |
| The Following User Says Thank You to maslin For This Useful Post: | Celigts (06-03-2019) |
| ABS , Slip indicator , check engine lights all on ( Not flashing ) | Enrique_13 | Issues | Warranty | Recalls / TSB | 5 | 10-09-2018 12:47 PM |
| Help needed! Check engine light after weird traction lights. | dillanp86 | Engine, Exhaust, Transmission | 3 | 12-08-2016 09:17 AM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| DTC Codes U0122 and U0131 | pleong | Electronics | Audio | NAV | Infotainment | 1 | 09-03-2014 01:40 AM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
