Old 12-08-2016, 01:33 AM   #1
dillanp86
dillanp86's Avatar
Drives: 2010 Acura TL
Help needed! Check engine light after weird traction lights.
Just got my OFT from modbargains in Black Friday and currently running stage 1 on competent bone stock rs1. Was going to try E85 tonight and was super excited, so as I was driving around trying to get my gas light on, I was right under my last quarter tank line and then abs and traction lights came on. I pulled over and restarted the car and then a check engine light was on, claiming these codes:
Also noticed that my LTFT was -5.47 almost the entire time and sometimes went up from +.78 to +2.38. Under hard acceleration both STFT & LTFT stayed at 0.00.
My OFT also was a bit buggy, it wouldn't read the ECU info and just had red question marks in places. Also only had the main menu pictures with no words. (JS). I tried quickly googling for the codes but couldn't find anything. Couldn't notice any signs of leaking from the fuel lines as well. I was however suppose to change my oil today, I know has nothing to do with the LTFT but I'm scared and need some answers.
Thanks again for the help!
dillanp86 is offline   Reply With Quote
Old 12-08-2016, 01:35 AM   #2
dillanp86
dillanp86's Avatar
ALSO noticed this was how my cord for the OFT came out the box new... is this normal?
Old 12-08-2016, 05:53 AM   #3
steve99
Is your gass cap screwed on you have some evap emissions codes
were you doing burnouts doughnuts drift etc as this can sometimes upset traction vcs system
Unusuall to get all those codes. Its possible you have a fault with vsc or wheels sensor steering sensor.
Clear the codes if they come back flash back to stock and take it to dealer
Old 12-08-2016, 09:17 AM   #4
dillanp86
dillanp86's Avatar
Wasn't drifting but did a little power slide, but nothing excessive or crazy at all. I guess I'll do that today. And yeah my gas cap is correctly on.
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-04-2014 11:27 PM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
