Old 06-02-2019, 12:31 AM   #15
maslin
Benz Tech
Drives: 2017 BRZ Premium
Originally Posted by Celigts View Post
So like ... 245 x 40 x 18?
I'm on 255 x 35 x 18
Would 245 x 40 x 18 fix my issue?
You have a 2” discrepancy front to rear, 25” to 27”. That’s a tall tall tire on the back, front is about stock.
245/35R18 front, 285/30R18 would get you back in the game, and back to stock height. If you would like to stick with a 285 out back.
maslin is offline   Reply With Quote
Old 06-03-2019, 10:25 AM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Any of the ones in green.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Celigts (06-03-2019)
Old 06-03-2019, 01:14 PM   #17
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
only issue here is that my rear tire would be shorter than my front tire ...
Would look really funky as the rear widebody is supposed to be larger looking...
Celigts is offline   Reply With Quote
Old 06-03-2019, 01:17 PM   #18
Celigts
Celigts's Avatar
I doubt i can get a 245/45/18 in there on the front. It already is paper thin close to rubbing
What if I brought the rears down to 285/35/18?
Would be a 3.6% difference from front/back.
Still I'd have Wheel speed sensor issues?
Old 06-03-2019, 01:42 PM   #19
Sportsguy83
Drives: Limited BRZ
I don't know what is the threshold for WSS to be fussing..... I personally wouldn't chance it at anything over 1.5% unless you can get proof from someone else that is known to have 3.6%+ difference and have been fine. I have only run a 1.2% difference and it was fine.
Old 06-03-2019, 01:57 PM   #20
Celigts
Celigts's Avatar
I'll create a new thread and ask. Hopefully can get some confirmed answers before I change my rear tires ...
Old 06-03-2019, 01:57 PM   #21
maslin
Benz Tech
The sizes I posted would be the same height front and rear.
Aspect ratio is the sidewall height as a percentage of the width. A wider tire with a smaller aspect ratio isn't necessarily shorter.
245/35 and 285/30 are nearly identical in height. If you want the t bucket Mickey Thompson look you're going to need a car without fancy electronics.
The Following User Says Thank You to maslin For This Useful Post:
ABS , Slip indicator , check engine lights all on ( Not flashing ) Enrique_13 Issues | Warranty | Recalls / TSB 5 10-09-2018 12:47 PM
Help needed! Check engine light after weird traction lights. dillanp86 Engine, Exhaust, Transmission 3 12-08-2016 09:17 AM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
DTC Codes U0122 and U0131 pleong Electronics | Audio | NAV | Infotainment 1 09-03-2014 01:40 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
