#15 |
Drives: BRZ 2018
Did I say performance anywhere?
If I move the front O2 sensor to other position it will be only for engine protection not for performance. And to go further the discussion every O2 sensor, even the second one, shouldn't be horizontally. Humidity from the exhaust gases when you turn off the engine will destroy it in the long term use! If you ask me the header you posted is not "right" at least for my needs (low-mid torque, torque dip elimination, driveability), IF I had to extract the last horse of my BRZ I'd buy an ACE header not one as the above nor the Gruppe-S, but thanks anyway! |
#16 |
Huge E85 fan!
Drives: 2016 Scion FRS
IMHO this is another reason to gut the OEM header. It's a well designed EL header with great heat shielding. I'd rather have the O2 sensor sniffing all 4 cylinders because if I get something like an injector stuck wide open, or a cylinder going dead lean from an injector getting clogged, there's only a 1 in 4 chance of that aftermarket header catching it.
I run an aftermarket AFR sensor anyway (for E85 without a FFK) but the OEM set up is well designed. |
| Throttle Position Sensor [Suspected Faulty] | Hags86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 09-29-2025 10:05 AM |
| Crankshaft position sensor bolt size | sfruski | Engine, Exhaust, Transmission | 0 | 09-01-2017 11:10 PM |
| How to calibrate Throttle position sensor FRS? | Binary_fission | Issues | Warranty | Recalls / TSB | 11 | 04-01-2017 01:37 AM |
| Aftermarket headers and o2 sensor placement?? | Mike86 | Engine, Exhaust, Transmission | 3 | 04-24-2014 12:41 PM |
| Cam position sensor harness help me need a part off a donor car | kiichiro | Engine, Exhaust, Transmission | 5 | 04-23-2014 05:19 PM |
