#15 |
Drives: 2013 frs
would it be possible that the wastegate is not opening?
Sent from my VTR-L09 using Tapatalk |
#16 |
Drives: JDL Turbo BRZ
That 100% looks like boost cut. MAP sensor is seeing nearly 16psi. Is your wastegate line routed correctly and attached to the bottom port of the wastegate? Top should be vented and the other end connected to the turbo compressor housing. Not sure who is tuning your kit, but in my case, I was told not to floor it until given the OK - and it definitely wasn't after the first revision .. more like the 4th or 5th revision.
For what it's worth, I was on the track a couple weeks ago and the wastegate line popped off and my log looked exactly like yours because I spiked to 14psi. It's a damn good thing there was a failsafe in place. |
#17 | |
Drives: 2013 frs
#18 |
Drives: UK GT86
Typically you set a boost limit and then when it hits that the fuel is completely cut. It's safety to prevent overboost. However it seems to cut at 2 bar MAP, which is 1 bar of boost. You could have it set low to ensure all is safe or is not used to the platform and set 2 bar limits thinking it was MRP.
.: Stealth 86 :.
#19 | |
Drives: Q5 + BRZ + M796
Edit: never mind you answered
#20 | |
A wastegate that doesn’t open would mean the boost would spike. One that sticks open would make it hard to inpossible for boost to build.
#21 | |
Drives: 2013 frs
#22 |
Drives: 2013 frs
took everything apart. the wastegate seems to be working properly. i used a soft spring and opened with my hands multiple times. so i dont think its the wastegate.. at this point im out of ideas, hardware wise
#23 |
Drives: UK GT86
Look at the log, when it happens the fuel quantity total goes to 0. It's in the tune.
.: Stealth 86 :.
#24 |
Drives: GT86, forged and supercharged
#25 | |
Drives: 2013 frs
#26 |
Drives: 2013 frs
#27 |
That is the question. Either the spring is sticking (unlikely if new and in good condition), or the spring is not the correct rating (ie 9psi, also possible but probably not likely), or the manifold pressure line going into the wastgate is leaking, cracked, not hooked up correctly, or has popped off (easily checked), or you are getting wicked boost creap (unlikely at your psi setting and turbo size).
#28 |
Drives: 2013 frs
this how the wastegate is set up
![]() ![]() ![]() Sent from my VTR-L09 using Tapatalk |
| Sudden Power Loss / Hesitation and jerking under WOT | Jesse36m3 | Forced Induction | 6 | 05-14-2018 09:59 PM |
| Engine bogging / stumble / hesitation / jerking during accelaration ard 2.5k - 3k RPM | mo420 | Issues | Warranty | Recalls / TSB | 24 | 07-29-2017 07:35 PM |
| CEL p0456 code, jerking when braking | RedNWhite | Issues | Warranty | Recalls / TSB | 7 | 06-03-2016 06:35 PM |
| M/T and idling over speed bumps - jerking | mstoochn | Issues | Warranty | Recalls / TSB | 7 | 04-29-2015 04:45 PM |
| Was I being hard on my car? | Fr-s13 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 07-04-2013 09:54 PM |
