Old 06-12-2018, 05:41 PM   #15
bryan.catano93
Drives: 2013 frs
would it be possible that the wastegate is not opening?
Sent from my VTR-L09 using Tapatalk
bryan.catano93 is offline   Reply With Quote
Old 06-12-2018, 05:47 PM   #16
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
That 100% looks like boost cut. MAP sensor is seeing nearly 16psi. Is your wastegate line routed correctly and attached to the bottom port of the wastegate? Top should be vented and the other end connected to the turbo compressor housing. Not sure who is tuning your kit, but in my case, I was told not to floor it until given the OK - and it definitely wasn't after the first revision .. more like the 4th or 5th revision.
For what it's worth, I was on the track a couple weeks ago and the wastegate line popped off and my log looked exactly like yours because I spiked to 14psi. It's a damn good thing there was a failsafe in place.
Jesse36m3 is offline   Reply With Quote
Old 06-12-2018, 06:00 PM   #17
bryan.catano93
Drives: 2013 frs
yeah i made sure that i was given the ok. he told me to grab one WOT log and 15 min of regular driving. yeah that is how i have it set up. it was a used kit so the wastegate was assembled already. there is one port blocked. maybe the blocked port is the wrong one? should i switch them?
Old 06-12-2018, 06:15 PM   #18
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by bryan.catano93 View Post
yeah its the first revision after the basemap. what could be causing the boost cut?
Typically you set a boost limit and then when it hits that the fuel is completely cut. It's safety to prevent overboost. However it seems to cut at 2 bar MAP, which is 1 bar of boost. You could have it set low to ensure all is safe or is not used to the platform and set 2 bar limits thinking it was MRP.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-12-2018, 06:24 PM   #19
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by Kodename47 View Post
I would say that looks like boost cut, probably on an early revision tune to make sure everything is OK.
How would there be boost cut without a boost controller? Isn’t his setup just mechanical? Do you mean the tune is cutting ignition and fuel?
Edit: never mind you answered
Old 06-12-2018, 06:28 PM   #20
Irace86.2.0
What is your wastegate spring rated to?
A wastegate that doesn’t open would mean the boost would spike. One that sticks open would make it hard to inpossible for boost to build.
Old 06-12-2018, 06:56 PM   #21
bryan.catano93
Drives: 2013 frs
its set to 9psi( green spring) and i need to double check the wastegate then. itll. be a pita to remove it with everything bolted up but no way around it lol
Old 06-12-2018, 11:05 PM   #22
bryan.catano93
Drives: 2013 frs
took everything apart. the wastegate seems to be working properly. i used a soft spring and opened with my hands multiple times. so i dont think its the wastegate.. at this point im out of ideas, hardware wise
Old 06-13-2018, 03:26 AM   #23
Kodename47
Kodename47's Avatar
Drives: UK GT86
Look at the log, when it happens the fuel quantity total goes to 0. It's in the tune.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-13-2018, 03:48 AM   #24
secho
secho's Avatar
Drives: GT86, forged and supercharged
I see that in the same way. It is in the tune. Looks Luke load limits are set at 2. It fuelcuts while you exceed this.
Odesláno z mého SM-G950F pomocí Tapatalk
secho is offline   Reply With Quote
Old 06-13-2018, 09:14 AM   #25
bryan.catano93
Drives: 2013 frs
i guess its a waiting game now, my tuner is only back saturday. wont drive the car until then just in case. i hope its the tune tbh.
Old 06-13-2018, 09:50 AM   #26
bryan.catano93
Drives: 2013 frs
why would i be overboosting tho?
Old 06-13-2018, 12:20 PM   #27
Irace86.2.0
That is the question. Either the spring is sticking (unlikely if new and in good condition), or the spring is not the correct rating (ie 9psi, also possible but probably not likely), or the manifold pressure line going into the wastgate is leaking, cracked, not hooked up correctly, or has popped off (easily checked), or you are getting wicked boost creap (unlikely at your psi setting and turbo size).
Old 06-13-2018, 12:55 PM   #28
bryan.catano93
Drives: 2013 frs
this how the wastegate is set up
Sudden Power Loss / Hesitation and jerking under WOT Jesse36m3 Forced Induction 6 05-14-2018 09:59 PM
Engine bogging / stumble / hesitation / jerking during accelaration ard 2.5k - 3k RPM mo420 Issues | Warranty | Recalls / TSB 24 07-29-2017 07:35 PM
CEL p0456 code, jerking when braking RedNWhite Issues | Warranty | Recalls / TSB 7 06-03-2016 06:35 PM
M/T and idling over speed bumps - jerking mstoochn Issues | Warranty | Recalls / TSB 7 04-29-2015 04:45 PM
Was I being hard on my car? Fr-s13 Scion FR-S / Toyota 86 GT86 General Forum 49 07-04-2013 09:54 PM
