Old 07-03-2017, 03:19 PM   #15
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
OK, you are on your own.
Tiny bit of wee going down my pants from laughing.
Keep it up.
Scrappydoo is offline   Reply With Quote
Old 07-03-2017, 06:59 PM   #16
alex.s
alex.s's Avatar
Drives: '17 BRZ Premium. Totaled: '16 FRS
Originally Posted by Scrappydoo View Post
No, my point was that if you want to improve heat loss from the disks then why not remove the shrouds?
I thought about this a lot more and did some napkin math and I'm even more confused now. let me illustrate some points and make no clear conclusion.
1. the rotors obviously pump air.
2. the rotors pump a lot of air. doing napkin math, the ducts are about half the size they need to be in order to provide enough air to the rotors that there would be positive pressure before the entrance to the rotor at 80mph.
3. when the rotor is pumping, and the shroud is in place, the rotor pulls air from the area that is shrouded. that means it pulls air over the surface of the rotor, then pumps it back out through the inside. this should be substantially more air flow / cooler air over the back rotor surface than it would see simply spinning by itself in standing air that wasn't being pumped.
4. if you remove the shroud, it should improve the rotor's pumping effect, which should help cool the inside of the rotor a lot. but you lose some effect of the pump on cooling the back surface of the rotor. however you dramatically increase the back surface of the rotor's radiative cooling capability. another side effect of going without the shroud is that the air going into the center of the rotor is cooler.
5. because of 3 and 4, running without a shroud will cause a higher heat differental in the back rotor surface, but should cool the front rotor plate better and give more even cooling on one side of the rotor versus the other.
there might be some impact on rotor life regarding heat differential... it might be that one way is better than the other. i suspect cooling from only the center would be more prone to cracking but i'm not entirely sure if the difference between one side of the rotor to the other would really be that high that cooling only on the inside and decreasing cooling on the rotor surface would have much of an impact on cracking...
so now i have no idea if the shroud is beneficial or not. at least it helps keep the dust down?
starting to lean toward the idea that it should be minimal shrouding.
alex.s is offline   Reply With Quote
Old 07-14-2017, 12:37 AM   #17
alex.s
alex.s's Avatar
Originally Posted by ApexEight View Post
Any pics of how the hose was routed around the radiator?
The Following User Says Thank You to alex.s For This Useful Post:
ApexEight (07-14-2017)
Old 07-14-2017, 03:19 PM   #18
Jonsey
Jonsey's Avatar
That many bends is going to have an impact on the flow rate due to all the back pressure.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 07-14-2017, 04:25 PM   #19
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
No back pressure. What from? Restricted flow maybe.
But not enough to make a gnats difference?
Old 07-14-2017, 04:35 PM   #20
alex.s
alex.s's Avatar
The bends cause a change in direction of the air. Body at rest stays at rest. Every action has equal opposite reaction. That means every change in direction requires energy. In other words the bends create a flow restriction. It's not massive but I would expect it to be at least 5 percent in my case
Sent from my Nexus 5X using Tapatalk
Old 07-14-2017, 05:11 PM   #21
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
And you can lead a horse to water but a pencil must be lead.
Old 07-14-2017, 05:22 PM   #22
alex.s
alex.s's Avatar
... what?
Old 07-17-2017, 04:19 PM   #23
Jonsey
Jonsey's Avatar
Bends in piping can create pretty significant reductions in flow, especially when that flow is not pressurized (the air flowing through is not pressurized or barely pressurized). Air will take the path of least resistance and if there is less resistance sliding sideways over the front of the bumper versus going though a long tube with numerous bends, it will take that path. I have only enough knowledge in this area from years of playing with aquarium piping and studying aerodynamics to get myself in trouble, but someone with more knowledge in fluid dynamics should chime in.
You might do some string testing to see if you are getting adequate flow.
I hope you are successful as routing on this car sucks and I am interested in doing something similar, I just have a feeling it won't be sufficient for heavy tracking by an advanced driver.
Old 07-17-2017, 06:46 PM   #24
Gunman
Drives: 2019 Mazda Miata RF
Shrouds do a lot, they 'shroud' heat from other areas, direct flow, even increase downforce if done right.
Gunman is offline   Reply With Quote
Old 07-17-2017, 10:29 PM   #25
stevesnj
stevesnj's Avatar
Originally Posted by wparsons View Post
That doesn't actually help as much as you would think. Vented rotors are cooled much better by directing air into the center and letting it flow out through the vanes.
This is pretty much how it's done.
My 2016 Build thread
FS: Velox Brake Duct Kit pleong Exterior Parts (Aero, Lighting, Etc.) 0 10-12-2016 07:14 PM
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
