Old 07-02-2017, 12:49 AM   #1
alex.s
alex.s's Avatar
Drives: '17 BRZ Premium. Totaled: '16 FRS
another DIY brake duct
cut out the fake ducts up front and plastic-welded in some modified funnels. 2" silicone duct from there, around the radiator to the inside, then out the side to the outboards. i cut the stock brake dust cover and welded on a 2" steel pipe and repainted it. worked out pretty well i think. it could be improved in a few ways... better / more open incoming duct... and a better end piece that blows it more directly on the center instead of right now its slightly off. but it should be better than nothing. cost was a couple bucks for the funnels, 80$ for the silicone ducting, and like ... i donno, 50c for the steel tube maybe? oh and the hose clamps... those must have been at least $1.
alex.s is offline   Reply With Quote
The Following 3 Users Say Thank You to alex.s For This Useful Post:
churchx (07-02-2017), Kenny_LongWrench (07-02-2017), OND (07-02-2017)
Old 07-02-2017, 10:52 AM   #2
Cole
Not a troll
Cole's Avatar
That's pretty neat, interested to see how they perform.
My only gripe is that the plastic vent looks a bit tough, but nothing that 20 minutes and some sandpaper or a file couldnt fix
Old 07-02-2017, 12:22 PM   #3
alex.s
alex.s's Avatar
yeah, i really should have just used a hot knife and done it myself. my brother went to town opening them up with a scalpel. it's not super noticeable in person unless you look for it. once i stop being lazy i'll print some molds and make a new set of the scoops in carbon fiber and make it look nicer. i just have to fix my printer first, which is kinda a pain in the ass.
The Following User Says Thank You to alex.s For This Useful Post:
Cole (07-02-2017)
Old 07-02-2017, 01:25 PM   #4
Evil Rocky
Drives: FRS
Very nice man! Where did you buy the hose and stuff?
Evil Rocky is offline   Reply With Quote
Old 07-02-2017, 02:42 PM   #5
alex.s
alex.s's Avatar
the silicone duct hose is from amazon. there was only one seller with prime and the hose looked nicer than the others. and then there was like a ton of weird other brands that didn't look as nice. so i paid the premium price of $80. oohhh la, la. I picked up the funnels from harbor freight while i was getting a little belt sander for my brother who started making knives. (guess what he was using to cut the backing off the fake vents? lol) i had the steel tube and other shit laying around.
wparsons (07-02-2017)
Old 07-02-2017, 04:23 PM   #6
stevesnj
stevesnj's Avatar
nice job!
My 2016 Build thread
Old 07-02-2017, 04:51 PM   #7
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Why not just take of the disk shroud?
Scrappydoo is offline   Reply With Quote
Old 07-02-2017, 10:06 PM   #8
wparsons
wparsons's Avatar
If you remove it you have to fabricate something else to attach the outlet from the hose to. The OEM shield is convenient since it's already the right shape/size, and is already drilled to mount behind the hub.
flickr
Old 07-03-2017, 12:11 AM   #9
alex.s
alex.s's Avatar
i looked through probably thousands of photos online and i came to the conclusion that it looks better in silver. please excuse my shit welds
Old 07-03-2017, 01:27 AM   #10
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Nice setup man. That hole in the fender liner is already there, right? Any pics of how the hose was routed around the radiator?
ApexEight is offline   Reply With Quote
Old 07-03-2017, 03:42 AM   #11
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
No, my point was that if you want to improve heat loss from the disks then why not remove the shrouds?
Old 07-03-2017, 07:55 AM   #12
wparsons
wparsons's Avatar
That doesn't actually help as much as you would think. Vented rotors are cooled much better by directing air into the center and letting it flow out through the vanes.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
chaoskaze (07-14-2017), Gunman (07-17-2017), stevesnj (07-17-2017)
Old 07-03-2017, 12:15 PM   #13
alex.s
alex.s's Avatar
no you gotta cut the hole but it's pretty easy and they have spots for you to cut out that make it look like its factory. and its not the fender liner, its the one right above the lower control arm. i'll try to grab some pics of the inner routing later today
Old 07-03-2017, 12:50 PM   #14
alex.s
alex.s's Avatar
i'm sure there is plenty of airflow on the surface with or without the shrouds. they have little vents in them as well. the rotor itself with the little vanes inside acts like a pump, when they spin the air around because the rotor is spinning, it pumps air through the center of the rotor. getting positive pressure going into that pump makes the pump vastly more efficient. more pump == more heat go bye bye.
wparsons (07-14-2017)
FS: Velox Brake Duct Kit pleong Exterior Parts (Aero, Lighting, Etc.) 0 10-12-2016 07:14 PM
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
