#15 | |
Drives: 2014 Premium Subaru BRZ AT
#16 | |
you can get same effect with cracked header or gasket leak in header before or near 02 sensors. At ilde and low rpm you will get fresh air sucked in between exhaust pulses. so gives you perceived lean condition and high positive fuel trims, but as rpm increases enough exhaust pressure to keep out fresh air and the trims go back to normal at higher rpm. |
#17 | |
Drives: UK GT86
P0171 is for lean condition
.: Stealth 86 :.
#18 | |
haha only one off :-) im going to put my money on that electronic maf bender box if its in use Last edited by steve99; 06-06-2017 at 07:14 AM. |
#19 |
#20 |
New BRZ Guy
Drives: 2022 Subaru BRZ
Is there any update on this if it ever got fixed? I'm having the same issue. Completely stock except on UEL catless header
#21 |
Señor Member
Do you have a tune to suit the UEL catless header?
1974 TA22 Celica
2013 86 GT |
#22 |
#23 |
Drives: 86 GT
This happened to me when I accidentally flashed K00G to a prefacelift, when it was meant for the facelift. From Techstream the 2nd O2 sensor voltage would not budge, and it gone away when I flashed back to A01G.
Far from the solution but I hope it helps someone. edit: and I found this https://www.ft86club.com/forums/show...postcount=1047
DIY stuff at Compelica Works
| Fuel pump voltage | nelsmar | Engine, Exhaust, Transmission | 9 | 12-01-2013 01:08 PM |
| FS: Pivot MegaRaizin Voltage Stabilizer | JPxM0Dz | Canada Classifieds | 0 | 07-29-2013 08:13 PM |
| Voltage Fluctuation | Andrew666 | Electronics | Audio | NAV | Infotainment | 5 | 04-21-2013 08:15 PM |
| Voltage fluctuations | Andrew666 | AUSTRALIA | 7 | 03-19-2013 09:44 AM |
