Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 03-17-2013, 09:55 PM   #1
Andrew666
Drives: 86 GTS
Voltage fluctuations
Hi has anyone noticed or experienced voltage fluctuation with their car.
I’m not sure if this is part of their fuel economy approach (decreasing alternator load therefore engine load) and only charging the battery when required. But I have notice on my Scan Gauge (also checked with a multimeter) that voltage fluctuates between 12.5 to 14.3 volts when driving the car above 1500 rpm at normal running temperatures without lights or other electrical accessories on. No warning lights come on or codes are set.
Thoughts?
Andrew666 is offline   Reply With Quote
Old 03-18-2013, 01:50 AM   #2
TheRedViking
TheRedViking's Avatar
Drives: Hypothetical 86 GT
I reckon it's probably normal.
TheRedViking is offline   Reply With Quote
Old 03-18-2013, 01:53 AM   #3
Nardi330
Nardi330's Avatar
Drives: 86
never looked at voltage much on my scangauge as i always concentrate on water and oil temp.
will have a good in the next few days and report back.
Nardi330 is offline   Reply With Quote
Old 03-19-2013, 04:06 AM   #4
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
yeah i haven't really looked at mine much, i think you are finding problems that don't exist. I honestly wouldn't worry unless you are close to or under 12v for extended periods.
86•BRZ is offline   Reply With Quote
Old 03-19-2013, 05:28 AM   #5
mswhong
ive had problems of my headunit cutting out here and there but it only happens on rare occasions.. Anyone else? Maybe this is linked to these voltage fluctuations.
mswhong is offline   Reply With Quote
Old 03-19-2013, 08:22 AM   #6
Nardi330
Nardi330's Avatar
Drives: 86
Mine is the same and it only happens not long after starting up for a few seconds. I think it might be doing something so maybe normal.
Old 03-19-2013, 08:34 AM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
I am sure anything that requires exact voltage would be in circuit with a voltage regulator. Momentary overvoltage by 10% or so shouldnt make a huge difference. Hardly a spike for things like lighting, etc.
Devices that are uber voltage sensitive (logic) are regulated and at a very low level via dedicated power supply (eg. 5V). At least that's the way it is with electronics that I tinker with. In a pinball machine a 12V unregulated line will easily reach 13.5V, but again it is unregulated.
If it aint broke, dont fix it.
Old 03-19-2013, 09:44 AM   #8
mswhong
It must be only in the early models (I'm assuming yours is).. i got mine way back in June/July
Voltage Fluctuation Andrew666 Electronics | Audio | NAV | Infotainment 5 04-21-2013 08:15 PM
