Old 06-04-2017, 04:40 PM   #1
bhaugen2
Drives: 2014 Premium Subaru BRZ AT
O2S2 Voltage Always Zero
Hey Everyone first post on here,
I have been having problems with my 2014 BRZ A/T for a while now with rough idle, frequent stalling, running rich. Most frequent codes I am getting are P0172. I have an AEM cold air intake. For awhile I had on an aftermarket UL header, but took it off thinking the O2 sensor positions being in a different position was causing the CEL. After going back to the stock header I still had same problems with CEL and problems listed above.
After digging into my OFT deeper I found that the O2S2 Voltage always reads zero and the Wideband AFR always reads >17.0. This made me think either two things. Either I damaged the O2 sensor when changing the headers around. Or I have a loose connection between the signal wire and the ECU (I probed through the signal wire on either sides of the connection and received resistance).
Thinking it was most likely a damaged sensor I bought a Walker Downstream O2 sensor (part#: 250-24440) and just replaced it. I turned on the car for a minute thinking I would seem some response to the O2S2 Voltage but it stayed at zero. Do I need to let the car run more and log the data to see if the values change? Should I next look for a loose connection? Could it be anything else?
Thank you in advance.
bhaugen2 is offline   Reply With Quote
Old 06-04-2017, 04:48 PM   #2
phrosty
Check for leaks and clean the MAF sensor. If those don't do it, probably damaged MAF or O2 sensor.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 06-04-2017, 04:49 PM   #3
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
It's the aem intake, get rid of it. It's known to make the car run rich. Take off the intake go back with oem and restall the headers and you'll be good
Dr. BRZ is offline   Reply With Quote
Old 06-04-2017, 05:09 PM   #4
bhaugen2
I have done both of those with checking for leaks and cleaning the MAF sensor. The MAF is reading correctly from the data I've pulled from the OFT. I agree that is my thought too but I just replaced the O2 sensor...
Old 06-04-2017, 05:11 PM   #5
bhaugen2
Why would the Wideband AFR read lean (>17.0) if the car is actually running rich (my MPG and nose can tell its running rich) along with the O2S2 voltage reading zero always?
Old 06-04-2017, 05:44 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
WBO2 is if you reuse the rear O2 input so just ignore. I put money on the fact the OFT doesn't log correctly for the rear O2. Suggest putting up your Cal ID and see if others have this issue.
Are you using the MAF box that comes with the AEM? I reckon the intake could be your problem.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-04-2017, 09:21 PM   #7
bhaugen2
Okay I will go back to stock and see if the problem is fixed. I will have to wait until september though as I won't be going back to where the CAI is located until then. Thank you everyone for the help!!!
Old 06-05-2017, 03:34 AM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you're running the OFT then just re-scale the MAF on your tune. It's an easy and quick fix. Are you running the MAF box that comes with the intake?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2017, 05:26 AM   #9
steve99
+1
That P0172 lean code usually means the ecu is applying over 30% fuel trim correction and the afr is still not correct. Not something you wsnt to leave till September. You might have other issues than the intake , you might have damaged 02 sendor or exhaust leak
Old 06-05-2017, 10:01 AM   #10
bhaugen2
Okay I will try to do a little research tonight on rescaling the MAF. And yes I am running the AEM MAF box that comes with the intake.
Old 06-05-2017, 10:06 AM   #11
bhaugen2
+1
The car is not running lean. I can smell exhaust fumes more strongly and my MPG is down to around 24 instead of in the 30's. Running rich should not damage the engine I would think? I will look at your MAF scaling post later tonight. I don't hear an exhaust leak, but it could be small. Just replaced the heated O2 sensor yesterday.
Old 06-05-2017, 01:14 PM   #12
wparsons
wparsons's Avatar
Running too rich will wash the oil off the cylinder walls and can lead to cylinder scoring.
I'll look at what rear O2 reads, but the bigger question is why you're looking at the wrong sensor? Just log AFR (primary O2) against commanded AFR as well as STFT and LTFT.
flickr
Old 06-05-2017, 07:10 PM   #13
steve99
Yes for some reason it appears the ecu is getting feedback that engine is running lean ie P0172, as its getting feedback that its lean it will be adding the maxium amout of enrichment it can via fuel trims which is over 30% most likely causing a very rich condition.
As above poster said you rearly need to diagnose the issue, simply scaling the maf to compensate for another fault , if thats the case, will not solve your problem
[ame]https://m.youtube.com/watch?v=5WnM_NsOtd8[/ame]
Old 06-05-2017, 09:17 PM   #14
bhaugen2
I was looking at all of these and they all seemed strange but when I saw zero voltage for a O2 sensor I thought that was causing all the problem since I didn't know it wasn't working on OFT.
Fuel pump voltage nelsmar Engine, Exhaust, Transmission 9 12-01-2013 01:08 PM
FS: Pivot MegaRaizin Voltage Stabilizer JPxM0Dz Canada Classifieds 0 07-29-2013 08:13 PM
Voltage Fluctuation Andrew666 Electronics | Audio | NAV | Infotainment 5 04-21-2013 08:15 PM
Voltage fluctuations Andrew666 AUSTRALIA 7 03-19-2013 09:44 AM
