Old 06-05-2017, 11:44 PM   #15
bhaugen2
Drives: 2014 Premium Subaru BRZ AT
Yes for some reason it appears the ecu is getting feedback that engine is running lean ie P0172, as its getting feedback that its lean it will be adding the maxium amout of enrichment it can via fuel trims which is over 30% most likely causing a very rich condition.
As above poster said you rearly need to diagnose the issue, simply scaling the maf to compensate for another fault , if thats the case, will not solve your problem
Great video! That helped me a lot. Still need to watch part 2, but based on part 1 and the graph above (along with RPM) most likely a vacuum leak
bhaugen2 is offline   Reply With Quote
Old 06-06-2017, 12:59 AM   #16
steve99
Drives: FT86
you can get same effect with cracked header or gasket leak in header before or near 02 sensors. At ilde and low rpm you will get fresh air sucked in between exhaust pulses. so gives you perceived lean condition and high positive fuel trims, but as rpm increases enough exhaust pressure to keep out fresh air and the trims go back to normal at higher rpm.
Old 06-06-2017, 03:07 AM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes for some reason it appears the ecu is getting feedback that engine is running lean ie P0172, as its getting feedback that its lean it will be adding the maxium amout of enrichment it can via fuel trims which is over 30% most likely causing a very rich condition..
P0172 - System Too Rich (Bank 1). It's the opposite to above. The system is at maximum negative trims.
P0171 is for lean condition
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-06-2017, 03:13 AM   #18
steve99
Drives: FT86
haha only one off :-)
im going to put my money on that electronic maf bender box if its in use
Old 06-06-2017, 10:13 AM   #19
bhaugen2
That is what I'm thinking as well. I'm going to see if I can get the stock CAI shipped to us and then see if that fixes it.
Old 05-03-2022, 10:38 AM   #20
ChesterV
New BRZ Guy
Drives: 2022 Subaru BRZ
Is there any update on this if it ever got fixed? I'm having the same issue. Completely stock except on UEL catless header
ChesterV is offline   Reply With Quote
Old 05-06-2022, 03:07 AM   #21
Turdinator
Señor Member
Turdinator's Avatar
Do you have a tune to suit the UEL catless header?
1974 TA22 Celica
2013 86 GT
Old 09-13-2022, 10:50 PM   #22
JoweeHolmes
Hey! Same issues right now, any tips on how you got this fixed?
JoweeHolmes is offline   Reply With Quote
Old 09-14-2022, 05:35 AM   #23
Compelica
Compelica's Avatar
Drives: 86 GT
This happened to me when I accidentally flashed K00G to a prefacelift, when it was meant for the facelift. From Techstream the 2nd O2 sensor voltage would not budge, and it gone away when I flashed back to A01G.
Far from the solution but I hope it helps someone.
edit: and I found this
https://www.ft86club.com/forums/show...postcount=1047
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Fuel pump voltage nelsmar Engine, Exhaust, Transmission 9 12-01-2013 01:08 PM
FS: Pivot MegaRaizin Voltage Stabilizer JPxM0Dz Canada Classifieds 0 07-29-2013 08:13 PM
Voltage Fluctuation Andrew666 Electronics | Audio | NAV | Infotainment 5 04-21-2013 08:15 PM
Voltage fluctuations Andrew666 AUSTRALIA 7 03-19-2013 09:44 AM
