Old 11-29-2013, 10:58 AM   #1
nelsmar
Arrow Fuel pump voltage
Has anyone tested the stock fuel pump voltage? I am wondering if there is a drop from battery voltage or not. I know @Dustin@Dynosty did a lot of testing on the limits of the OEM pump, any chance voltage was verified? I am trying to see if it might be worth running power direct to the battery to get a little more flow out of the pump as our canister is a tad cramped to be installing say an aero 340 pump.
Also if anyone has pump flow charts at alternate voltages that would be superb! I was considering just using a boost-a-pump rather than trying to heavily modify the OEM carriage, or having to use a surge setup just to get a larger pump in. A boost-a-pump or direct wire is far cheaper than some alternatives that are currently on the market for higher horsepower levels.
Just for reference I personally am using a DW65C pump, and I think I'm going to be wanting just barely more than this pump will push out on E85, not enough to warrant $1000-$2000 fuel supply upgrades.
My flickr - Canibeat
Local magazine scout
Old 11-29-2013, 11:43 PM   #2
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I wouldn't worry about the voltage drop unless you get to the limits of what it can do.
I did run a dedicated larger wire to my fuel pump(walbro) in my s/c grand prix because I had everything (boost, fuel injectors, etc) at their limits before I had to upgrade things again.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 11-30-2013, 01:35 AM   #3
Ross
Drives: 85 corolla gts
What are your power goals?
Ross is offline   Reply With Quote
Old 11-30-2013, 03:59 AM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
hmmm...in for more info
I remember now on my Srt-4 a fuel pump rewire(with relay) was a popular/needed mod when running more boost.
Old 11-30-2013, 06:54 AM   #5
troek
troek's Avatar
Drives: 2012 Toyota 86
popular on r32s as well as it had a resistor in the line that would cut fuel pressure while idling to prevent fuel from needlessly cycling through the engine bay. it didnt always work and would short you on the voltage. is that realy a problem on a car as new as this?
Old 11-30-2013, 10:36 AM   #6
nelsmar
400-550whp on e85. Which surpasses the flow ability of a dw65c by a fair margin at 12v. The reason I am asking is I know I will be pushing till my pump maxed out at current. I figured since I will be looking into this I would make a thread (as I couldn't find one) so that way if I end up with information or someone else does it can be easily searchable
Mind you im dropping the compression a bit to increase my power on pump gas as well. So my manifold pressure will be higher than the guys on the stock internals pushing these power levels. This will require more PSI manifold pressure to compensate for decreased compression ratio to obtain the same power. One tuner i spoke to started leaning out near the 500WHP mark on the I believe it was the larger walbro pump (sometimes called the walbro 400LPH, or 430LPH). As I will be pushing a tad more manifold pressure to make the same power level this would 'shift' the pumps efficiency range to a less efficient range. These small pumps can do wonders on N/A cars for high power but E85 + higher boost they start to fall off a lot.
Old 11-30-2013, 10:39 AM   #7
nelsmar
Some cars are simply regulated. Iirc our cars Ecu can request pump duty cycle. So I don't know if this is pwm, raw voltage, or some other method for duty. So somewhere there is logic for our pump and for all I know it's based on 12v logic with a voltage cap.
Old 12-01-2013, 11:47 AM   #8
srt4_night_rider
Had to do it to my srt-4 as well, there would be a drop in the fuel pressure up top if you didn't rewire it.
srt4_night_rider is offline   Reply With Quote
Old 12-01-2013, 11:55 AM   #9
s2d4
s2d4's Avatar
This page has what you are after
http://*************/forums/f34/frs-f...kthrough-1179/
btw, it also shows the fallacy in 1000cc injectors kits and run it at like 15% for some idiotic reason.
Old 12-01-2013, 01:08 PM   #10
nelsmar
Almost nothing related to what I am talking about in this thread, although it is a great post. I am looking for the voltage supplied to the OEM pump by our car, not on a test bench. My car is currently in storage and I won't have time to do any testing for a number of weeks on the voltage that the car is supplying to the fuel system. going from 12v to 13.5v can give a nice bump in fuel flow.
battery, boost-a-pump, fuel pump, fuel system, voltage
Fuel pump issues jamesm Software Tuning 17 07-10-2018 05:46 AM
FS: Visconti Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 0 03-31-2013 04:45 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
