Old 01-29-2017, 07:28 PM   #15
ajh88
Drives: 2013 Firestorm FR-S
OK it was a blown EFI CTRL fuse. Replaced with one of the spares and she started right up. When I originally did the intake install I stupidly left the battery connected. Assume that blew it? Would love for someone to chime in and educate me on why this migt have happened. I am an electrical noob.
And thank you everyone for the help!
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
The Following 3 Users Say Thank You to ajh88 For This Useful Post:
DandoX (01-29-2017), guybo (01-29-2017), tooslow4umayne (01-30-2017)
Old 01-29-2017, 07:28 PM   #16
FirestormFRS
Did you remove any ground wires that didn't get reinstalled?
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
Overdrive (01-29-2017)
Old 01-29-2017, 10:43 PM   #17
steve99
Originally Posted by ajh88 View Post
I dont have that symbol at all... 2013 with regular key (no push to start or keyless entry stuff).
Arrh ok i think the key start models should crank and even start if key code not read but will cutout after about 5 seconds with no code , not ,100% on this though.
check fueses anything to do with ecu or ignition like they other guy said
of you have a device to read edu error codes that may help
Old 01-29-2017, 10:46 PM   #18
steve99
if i get a chance ill look at the wiring schematic, often a fuse like efi control will feed several circuits like ecu and sensors the unplugged maf cable may have shorted to ground or similar
Old 01-29-2017, 11:53 PM   #19
ryoma
ryoma's Avatar
when I installed my Grimmspeed CAI, I didn't unplug my battery. I had no blown fuses and the car started right up. not sure why your fuse blew but it shouldn't be normal. I never unplug my battery because I'm lazy and don't want to reset my radio channels lol
Old 01-30-2017, 12:55 AM   #20
steve99
Checked the wiring diagrams the EFI CTRL fuse feeds power to a whole lot of sensors (VVT , port injectors ,vvt position sensors, CPC solenoid) including the MAF sensor. Id sat somehow the maf sensor cable red wire B+ pin got shorted to earth at some point
Sportsguy83 (01-30-2017)
Old 01-30-2017, 06:49 AM   #21
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
For something simple like an intake I never disconnect my battery either (same reason- I don't want to have to pair my phone and reset radio stations) but I do pull the ECU fuse to reset the fuel trims.
That's really weird. How the hell did it blow that fuse once you got the car started?
How do you like the intake so far?
Old 01-30-2017, 08:29 AM   #22
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
This. It is an intake.
Old 01-30-2017, 12:21 PM   #23
guybo
Huge E85 fan!
guybo's Avatar
It must be related to this. I have no clue how you can mount the MAF wrong, but I have never seen this intake before either. I'm thinking you're right on, steve
3. Realized I may have not followed directions totally and the MAF was slightly off where it should have been.
4. Repositioned MAF as it should have been. Took neg battery terminal off for a while to let ECU reset.
Old 01-30-2017, 06:34 PM   #24
ajh88
The Blitz Advance intake has a small plate sandwiched between the intake and the MAF, and since the instructions were in japanese I inadvertently put two of the screw sleeves on the wrong side of the sandwich. This positioned prevented the MAF sensor from going all the way down into the chamber, by maybe a centimeter (however long the screw sleeves are). But it was enough to upset the MAF reading to make the engine shut off.
This is my daily so once I got everything running again I held off on the install. Will revisit this weekend. Got a SARD quad exhaust and TRD bumper garnish to put on too - arrived today - if I'm feeling ambitious. But it's cold...
2013 Firestorm FRS
Advanced Keys Push to Start Install in progress For the FRS. milkesfrs Cosmetic Modification (Interior/Exterior/Lighting) 117 04-25-2020 04:17 AM
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 06:20 PM
HELP! After Unichip install, car won't start!!! husker741 Issues | Warranty | Recalls / TSB 21 01-10-2015 11:50 PM
Shop to install Viper alarm/start? l0aded Southern California 0 05-04-2014 07:57 PM
Schematic for remote start install? empower-auto Electronics | Audio | NAV | Infotainment 3 07-31-2012 06:13 PM
