#15 | |
Drives: Harrop TVS86 STi BRZ tS
I used DBA rotors. Next time I would rather use ap racing 2part rotors for weight saving but I know that won't be your concern. Pretty much everyone I've seen with the conversion has been using DBA. They're good stuff with a much larger heat capacity.
#16 | |
Could you provide me with the part number for the DBA rotors? I know I have to get the ones that are dual drilled for our cars lug pattern but there are two different options on their catalog. |
#17 | |
Yeah the fronts are BA4654S-10Rears (non-slotted): DBA42656-10 The -10 denotes the dual drilled or 10 slot on all their products.
| The Following User Says Thank You to kuczynskika For This Useful Post: | eddyy (04-19-2016) |
#18 |
#19 |
Drives: 2013 satin white brz limited
Then by all means get them and turn your car into a show piece...
| The Following User Says Thank You to jasonojordan For This Useful Post: | eddyy (04-19-2016) |
#20 |
Drives: 2013 Ultramarine FR-S
@eddyy Did you ever order those brakes from Autozone? I am showing out of stock for them unfortunately.
#21 | |
Not yet. They have them in stock at a local store near my house. I was waiting till I get back to pick up a set. |
| The Following User Says Thank You to eddyy For This Useful Post: | DustinS (04-25-2016) |
#22 |
Lucky. Their website says In Stock, but they are definitely out of stock. Had an employee check and even called the main office. Post up pictures when you pick them up!
#23 |
First 86 owner for LIFE
Drives: 2013 First 86 FR-S
Have this full swap for sale off of an FRS, PM me if interested...
#24 |
Drives: 13 White MT FR-S
97B01339A 97B01339B are the remanufactured rear calipers and they show up for $133+$32 core charge.
#25 |
https://www.fastwrx.com/collections/...ti-rear-rotors KNS/DBA BRAKE ROTORS 2008-2014 STI are the cheapest rear rotors I can find with the 5x100 pattern $209 for the set
#26 |
Can confirm that these fit, and I got them for 200$ 50$ for brake lines, 200$ for rotors, and $300 for pads.
#27 | |
Drives: 2013 WRB BRZ Limited
I just ordered a full front/rear set to powdercoat, and was curious what they did/didn't come with. -B |
#28 |
yes it came with all the hardware.
| Full Front and Rear 08-12 STI Brakes Swap | King Tut | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 320 | 02-06-2020 01:37 AM |
| Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc | smellslikecurry | Brakes, Suspension, Chassis | 27 | 08-15-2014 11:52 AM |
| SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear | Amalgamo | Brakes, Suspension, Chassis | 3 | 04-24-2014 07:22 AM |
| Help me replace my rear brakes? | PoWn3d_0704 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-28-2014 03:55 PM |
| GTS Complete Brakes front & rear 294mm | hooman | AUSTRALIA | 2 | 09-24-2013 12:11 AM |
