Old 04-18-2016, 09:20 PM   #1
eddyy
eddyy's Avatar
STI Front and Rear Brakes
So I hate to beat a dead horse but I recently came across a much cheaper route to installing STI calipers on my FR-S. (or so it seems)
Heres the thread on how to install them:Full Front and Rear 08-12 STI Brakes Swap
I was searching for a set of used front and rear STI calipers and rotors to use then i came across these for a fraction of the price. $122 per front caliper and $160 per rear caliper. The best part of these are is the paint is already stripped and ready to be powder coated. (keep in mind that the images are not of the actual parts, but if you read the specs, they show that the fronts are indeed the STI 4 piston front calipers and STI 2 piston rears)
This almost seems too good to be true so when I get home in two weeks I'm going to order these to my nearest auto zone and give it a shot. If they bolt up, I'm going to pick up STI rotors and pads to complete the upgrade. If not, Ill just return the unused parts and update you guys.
Oh and one more thing, I don't plan on doing much or maybe even no track days. This is mostly aesthetics that I want, oh well, call me a ricer. Its what I like that matters.
Thoughts?
eddyy is offline   Reply With Quote
Old 04-18-2016, 09:47 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Don't forget the core charge.
-alex
Edit: also don't forget to pick the actual car. Once you select, then you'll find the initial link is useless.
Old 04-18-2016, 09:51 PM   #3
eddyy
eddyy's Avatar
You're right, I guess I should have mentioned that I had selected parts for a 2009 STI.
Auto Zone part numbers:
Front: (Right) D3699 (Left) D3698
Rear: (Right) D3781 (Left) D3780
Old 04-19-2016, 12:23 AM   #4
Irace86
Drives: BRZ + Ducati M796
-alex
So that core charge ads another 140 to this set, right?
How about rotors?
Irace86 is offline   Reply With Quote
Old 04-19-2016, 12:58 AM   #5
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Thoughts?
Oh man... Be careful here... Check out my build thread for the details (I tried a conversion), but long story short you are going to have to flip the bleeders to maintain proper piston orientation. Sounds easy (normally would be), but with older heavily used calipers the bleeder plugs are often seized inside the caliper and impossible to remove unless you drill them out and rethread.
Brand new calipers are no problem, but I bought an older pair first, drilled em out, rethreaded and they leaked under pressure. Its a tough/risky business unless you buy lightly used or brand new calipers.
Otherwise the install is easy. Get the proper rotors and the proper mounting bolts and the calipers bolt up just fine. Older calipers may need a conversion mounting bracket so do your research and read your threads!
kuczynskika is offline   Reply With Quote
The Following User Says Thank You to kuczynskika For This Useful Post:
SunkenFRS (01-13-2018)
Old 04-19-2016, 01:30 AM   #6
mav1178
mav1178's Avatar
How about rotors?
Correct.
This is only for calipers and no rotors, no pads, just calipers and pad retaining hardware.
-alex
Old 04-19-2016, 08:59 AM   #7
eddyy
eddyy's Avatar
How about rotors?
Yes you do have to add the core charge however, if you take the old parts that you're replacing they wont charge you the core fee. Most Auto zone employees don't really seem to know very much about what you take back to them and I want to keep my OEM parts so ill end up taking them a set of calipers that i have lying around from a 98 civic. Ive done it before with a CV joint.
I am aware of having to swap the bleeders and i do have the tools to be able to do this. Since these are brand new calipers it will be a lot easier to break the red thread lock that they use on them.
What rotors did you use and did you need spacers? Ive been trying to find the ones listen in the DIY and cant seem to find them.
The Following User Says Thank You to eddyy For This Useful Post:
illmatic (04-19-2016)
Old 04-19-2016, 10:47 AM   #8
Irace86
But they also could open the box and say these calipers are different, so we can't take them. But you are right, it may not matter to them, as long as they get a set to refurbish.
And these aren't new. They are refurbished says the specs.Which means they could have very limited stock. Also, it is likely they removed the bleeder nipples, but they could leave them be too.
Old 04-19-2016, 10:55 AM   #9
eddyy
eddyy's Avatar
You're right, i didn't even see that they're refurbished. Maybe that will make it easier to switch the bleeders. As for stock, I had already called my local store and they said they could have them at their store within a week of ordering them.
Old 04-19-2016, 11:00 AM   #10
jasonojordan
Drives: 2013 satin white brz limited
Ive said it before ill say it again. The braking capacity of our cars far exceeds the tires that were installed on it from factory. Install better tires perhaps a better pad and rotor and it will suit you needs for far cheaper and far less work then doing this route your going.
jasonojordan is offline   Reply With Quote
Old 04-19-2016, 11:21 AM   #11
Irace86
I'm a brake newbie. I know enough to know that big brake kits are mostly about avoiding heat, and I won't be tracking my car. Just spirited driving and the occasionally rare track day. At this point, the kit would be mostly to fill the void created from larger rims--aesthetics. Could I just put larger rotors on? I thought the rotor diameter couldn't be changed because the caliper would be able to bolt to the bracket.
Old 04-19-2016, 11:26 AM   #12
jasonojordan
No rotors have to match the caliper size. You only need large brake kits when you are a serious track guy. Hundreds of people do the occasional track day on stock brake calipers. They just change the fluid pads and rotors.
Old 04-19-2016, 11:30 AM   #13
Irace86
Thats what I thought. So, this is likely the cheapest route for aesthetics for certain.
Old 04-19-2016, 12:59 PM   #14
bass_114
bass_114's Avatar
Drives: wrb brz
I am doing the same upgrade on friday for the same reason and not because race car lol...
for rotors got dba 2656-10 for the rear and plain centrics for the front and not so aggressive pads to compensate since daily driven as well as 20mm spacers for the front to fit stock mags and back should clear without a spacer.
bass_114 is offline   Reply With Quote
Full Front and Rear 08-12 STI Brakes Swap King Tut Suspension | Chassis | Brakes -- Sponsored by 949 Racing 320 02-06-2020 01:37 AM
Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc smellslikecurry Brakes, Suspension, Chassis 27 08-15-2014 11:52 AM
SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear Amalgamo Brakes, Suspension, Chassis 3 04-24-2014 07:22 AM
Help me replace my rear brakes? PoWn3d_0704 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-28-2014 03:55 PM
GTS Complete Brakes front & rear 294mm hooman AUSTRALIA 2 09-24-2013 12:11 AM
