Old 12-03-2012, 02:31 PM   #1
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Thumbs up Full Front and Rear 08-12 STI Brakes Swap
The keys to the swap are to move the bleeders on the front calipers from the bottom to the top. This involves removing an allen head bolt and swapping it for the bleeders from the bottom. The other key is getting the DBA rotors that are dual drilled for 5x100 and 5x114. The only hard part is cutting off the rear dust shield as it won't work with the new larger rotors and it doesn't unbolt like it does in the front. I used a set of tin snips as I couldn't get my cut off wheel in there at a good angle. The brake lines are setup for the OEM calipers, but you can easily find a good angle to tighten them down to the caliper. The dimensions of the rear hat are correct for the BRZ parking brake, so that works perfectly as well. My wheels are 18x8 +42 and there is plenty of clearance in the rear, but not much clearance in the front.
2008-2012 STI Front and Rear Calipers
2008-2012 STI DBA 4000 Series T3 Rotors
2008-2012 STI Hawk HPS Pads
BRZ Goodridge G-Stop Braided Stainless Steel Brakeline Kit
ATE Super Blue Racing Brake Fluid
Always welcome any comments or questions.
The Following 30 Users Say Thank You to King Tut For This Useful Post:
ATL BRZ (12-03-2012), azian_advanced (08-19-2013), Bristecom (12-04-2012), chanomatik (12-02-2014), Cross (04-15-2015), disgruntld (01-15-2013), diss7 (08-24-2013), GTB/ZR-1 (12-03-2012), Guff (01-12-2013), humanshield (05-23-2013), Jay2420 (06-10-2014), Jesse (12-29-2012), LeeMaster (12-03-2012), mou (04-22-2013), nix (12-04-2012), normancw (04-29-2013), Ornelas66 (04-14-2015), P@ul (04-25-2014), PRORICAN (12-04-2012), R2RO (05-23-2018), Raven86Project (09-27-2018), slava (10-28-2014), Spartan65 (04-29-2013), StRacngtC06 (05-07-2014), Superhatch (12-03-2012), Surok (12-17-2012), TouchMyHonda (03-26-2013), Wes (12-03-2012), xkalelx (12-31-2014), zohare (01-12-2013)
Old 12-03-2012, 02:41 PM   #2
wparsons
wparsons's Avatar
Will the fronts clear 17" wheels? Looks good!
flickr
Old 12-03-2012, 02:43 PM   #3
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Great work!
Some install pics would be nice. Also, how do they feel compared to the stock brakes? Have you given them a good pounding yet?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 12-03-2012, 02:53 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I haven't given them a good pounding. Pedal feel is good, and I would definitely swap to some more aggressive pads at the track. I meant to take pics during the install, but once my hands get dirty then that plan normally goes out the window. I can probably pull the wheels and take some more pics and take pics of the removed dust shields.
Old 12-03-2012, 02:55 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I think it would be close. Looks like a little less than an inch of clearance from the top of the caliper to the barrel of the wheel.
Old 12-03-2012, 03:04 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Looks good
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-03-2012, 03:07 PM   #7
zuldajin
zuldajin's Avatar
Drives: K24 Swapped FRS
Looks hawt!
where'd you get the calipers/rotors? I'm thinking of getting this done to my BRZ once it arrives.
Thanks
zuldajin is offline   Reply With Quote
Old 12-03-2012, 03:15 PM   #8
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Fantastic!
Well done!
GTB/ZR-1 is offline   Reply With Quote
Old 12-03-2012, 03:16 PM   #9
itdansharpe
itdansharpe's Avatar
Very cool.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 12-03-2012, 03:27 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by zuldajin View Post
Looks hawt!
Thanks
I got the four calipers used off a member on NASIOC for $1400 (definitely better deals out there, but this was the only set of 08-12s I could find for sale used), rotors/pads from a vendor on NASIOC for $700, and the brake lines were about $100 from Tire Rack. I had the ATE fluid as I use it for my SpecE30. I definitely feel it was worth the $2200 investment. I also looked at all the Subaru parts stores online, and the best deal I could find for the calipers brand new was $2200 if you want to go that route. I figured the $800 savings was worth going used.
The Following User Says Thank You to King Tut For This Useful Post:
Old 12-03-2012, 03:43 PM   #11
OrbitalEllipses
Drives: Attitude
Tip for the rear dust shield: drill out the spot welds. That's what I did when I changed my WRX rears from stock to the "H6" upgrade.
Old 12-03-2012, 03:48 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I didn't remember seeing any spot welds to drill out. I will have to take a closer look.
Old 12-03-2012, 04:04 PM   #13
OrbitalEllipses
Drives: Attitude
Blarg. They may have changed that with the whole rear suspension. I'd check 3GWRX.com or NASIOC to see what the Impreza rear spindle assembly looks like as ours should be identical to that chassis model. I drilled out the spot welds on my GD chassis WRX, but that may have changed.
Old 12-03-2012, 05:06 PM   #14
DarkSunrise
DarkSunrise's Avatar
Nicely done. I liked the stock brakes on my old STI, I can only imagine how good they'd be on a lighter car like the BRZ.
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 12:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 05:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 10:08 AM
