Old 04-19-2016, 02:26 PM   #15
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Originally Posted by eddyy View Post
Yes you do have to add the core charge however, if you take the old parts that you're replacing they wont charge you the core fee. Most Auto zone employees don't really seem to know very much about what you take back to them and I want to keep my OEM parts so ill end up taking them a set of calipers that i have lying around from a 98 civic. Ive done it before with a CV joint.
I am aware of having to swap the bleeders and i do have the tools to be able to do this. Since these are brand new calipers it will be a lot easier to break the red thread lock that they use on them.
What rotors did you use and did you need spacers? Ive been trying to find the ones listen in the DIY and cant seem to find them.
I used DBA rotors. Next time I would rather use ap racing 2part rotors for weight saving but I know that won't be your concern. Pretty much everyone I've seen with the conversion has been using DBA. They're good stuff with a much larger heat capacity.
kuczynskika is offline   Reply With Quote
Old 04-19-2016, 02:36 PM   #16
eddyy
eddyy's Avatar
Originally Posted by jasonojordan View Post
Ive said it before ill say it again. The braking capacity of our cars far exceeds the tires that were installed on it from factory. Install better tires perhaps a better pad and rotor and it will suit you needs for far cheaper and far less work then doing this route your going.
This is a purely aesthetic modification for me. I bought Enkei RS05RR and wrapped them with Bridgestone Potenzas so I think I am good with tires even though I will probably be doing no hard driving or track days.
Could you provide me with the part number for the DBA rotors? I know I have to get the ones that are dual drilled for our cars lug pattern but there are two different options on their catalog.
eddyy is offline   Reply With Quote
Old 04-19-2016, 03:10 PM   #17
kuczynskika
Yeah the fronts are BA4654S-10
Rears (non-slotted): DBA42656-10
The -10 denotes the dual drilled or 10 slot on all their products.
The Following User Says Thank You to kuczynskika For This Useful Post:
eddyy (04-19-2016)
Old 04-19-2016, 03:29 PM   #18
eddyy
eddyy's Avatar
Thank You!
Old 04-19-2016, 03:46 PM   #19
jasonojordan
Drives: 2013 satin white brz limited
Then by all means get them and turn your car into a show piece...
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
eddyy (04-19-2016)
Old 04-22-2016, 12:46 PM   #20
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
@eddyy Did you ever order those brakes from Autozone? I am showing out of stock for them unfortunately.
Old 04-25-2016, 03:05 PM   #21
eddyy
eddyy's Avatar
Not yet. They have them in stock at a local store near my house. I was waiting till I get back to pick up a set.
The Following User Says Thank You to eddyy For This Useful Post:
DustinS (04-25-2016)
Old 04-25-2016, 03:45 PM   #22
DustinS
DustinS's Avatar
Lucky. Their website says In Stock, but they are definitely out of stock. Had an employee check and even called the main office. Post up pictures when you pick them up!
Old 04-26-2016, 02:14 AM   #23
AustinTCLN
First 86 owner for LIFE
AustinTCLN's Avatar
Drives: 2013 First 86 FR-S
Have this full swap for sale off of an FRS, PM me if interested...
AustinTCLN is offline   Reply With Quote
Old 12-04-2020, 04:17 PM   #24
ML
ML's Avatar
Drives: 13 White MT FR-S
97B01339A 97B01339B are the remanufactured rear calipers and they show up for $133+$32 core charge.
Old 12-04-2020, 04:33 PM   #25
ML
ML's Avatar
https://www.fastwrx.com/collections/...ti-rear-rotors KNS/DBA BRAKE ROTORS 2008-2014 STI are the cheapest rear rotors I can find with the 5x100 pattern $209 for the set
Old 12-17-2020, 02:31 PM   #26
ML
ML's Avatar
Can confirm that these fit, and I got them for 200$ 50$ for brake lines, 200$ for rotors, and $300 for pads.
Old 05-23-2021, 11:04 PM   #27
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Attachment 195792
Did they include hardware for the pads? or mounting bolts for the hub?
I just ordered a full front/rear set to powdercoat, and was curious what they did/didn't come with.
-B
HeresMyMind is offline   Reply With Quote
Old 05-24-2021, 08:56 AM   #28
ML
ML's Avatar
-B
yes it came with all the hardware.
Full Front and Rear 08-12 STI Brakes Swap King Tut Suspension | Chassis | Brakes -- Sponsored by 949 Racing 320 02-06-2020 02:37 AM
Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc smellslikecurry Brakes, Suspension, Chassis 27 08-15-2014 12:52 PM
SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear Amalgamo Brakes, Suspension, Chassis 3 04-24-2014 08:22 AM
Help me replace my rear brakes? PoWn3d_0704 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-28-2014 04:55 PM
GTS Complete Brakes front & rear 294mm hooman AUSTRALIA 2 09-24-2013 01:11 AM
