Old 02-28-2014, 01:11 AM   #1
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
Help me replace my rear brakes?
I have Wilwood brakes for all four corners. The fronts were straightforward and easy. The rears have the parking brake, and I have no idea what to do. I have never done rotors/calipers before, and in fact, never even done brake pads.
The wilwood manual says to refer to the service manual, and I cant actually find a section on rear brake removal, just the allowable tolerances and how to adj. the parking brake.
If there is a write up somewhere, that would be awesome. If it's just 'remove the bolts and go' then someone should let me know.
Thanks, John.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 02-28-2014, 02:40 AM   #2
CoupedUpSubie
Drives: 2013 BRZ Limited
To remove the rears all you need to do is back the parking brake adjuster all the way off. This allows the rotor to slide over the shoes. Then the rotor should come off just like the fronts. There is a DIY on doing the rear wheel studs which shows removing the rear rotors somewhere.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 02-28-2014, 10:51 AM   #3
sshole
Are you trying to swap from OEM to the Wilwoods? If so, you need to do the following (although not a step by step, these instructions should get you to where you need to be):
Jack up car
Disengage parking brake
Remove wheels
Remove OEM calipers from hub (2x bolts)
Disconnect brake line from OEM calipers (have something ready to catch brake fluid or pinch off brake line)
Remove OEM rotors from hub (if stuck, use 2x M8x1.25 bolts I believe)
Install new stuff using whatever hardware you received with your brake kit
Flush the brake fluid
Reinstall wheels
Engage parking brake
Lower car onto road
Test drive/bed in new brakes
sshole is offline   Reply With Quote
Old 02-28-2014, 03:08 PM   #4
PoWn3d_0704
@sshole, I figured out disassembly and am now reassembling the suckers. Just going to look up how to actually adjust the parking brake now.
Build Album:
Old 02-28-2014, 03:55 PM   #5
sshole
Parking brake as in the drums? There is a worm gear (or whatever it's called) that you spin to move the drum pads inwards and outwards. Adjusting them can be time consuming, though, since you have to constantly go back and forth between the hub and the parking brake lever to check tightness.
Full Front and Rear 08-12 STI Brakes Swap King Tut Suspension | Chassis | Brakes -- Sponsored by 949 Racing 320 02-06-2020 01:37 AM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
GTS Complete Brakes front & rear 294mm hooman AUSTRALIA 2 09-24-2013 12:11 AM
Swapping rear brakes to match Stoptech BBK Pneub Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-17-2013 02:01 PM
Rear brakes on base gt model of gt86 acro Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-01-2013 10:09 PM
