#15 |
Drives: 2023 WRB BRZ (MT)
so what do u think? go with decent speakers or a well tuned system? especially with OEM+ its being a tuned 3way
#16 |
Drives: Specialized Hardrock
Well tuned system always beats just adding better speakers.
| The Following User Says Thank You to TOOSTUBBORN2FAIL For This Useful Post: | lbroskee (03-11-2016) |
#17 |
then looks like I'm saving up $1200 for their full speaker setup and adding a good sub later. i had the original base system b4 but sold it due to an emergency =/ and the sub was weak... 100 watt RMS and i was always messing with bass settings
#18 |
In fact, I would bet my house that I could install a $800 processor and multi-channel amp and get better sound with the stock speakers than buying $800 speakers, a multi-channel amp, and no processor.
I should add, this is provided you are worried about sound quality first. |
#19 | |
#20 |
I understand that, my point was just to highlight the importance of proper tuning for each car.
#21 |
#22 |
@TOOSTUBBORN2FAIL i just realized they have that $800 option you just talked about and for $400 more you get all 8 speakers too
#23 |
Drives: 14 BSP Edelbrock BRZ
Or for the same money you could get an aftermarket headunit that has AndroidAuto and AppleCarplay built in along with time alignment and autoEq, a set of components, an amp and a sub. Lots of different ways to go when you define what your budget is. You could get decent components and a digital amp for a lot less than $800, thought you wanted this on the cheap.
#25 |
Those auto eq units are horrible.
I am curious what a digital amp is? |
#26 |
Yes, sorry, let's be anal about it and pretend to not know what I'm talking about. Class D amps. I'll leave you enthusiasts to continue, I've never won anything in IASCA.
Sent from my Nexus 6 using Tapatalk |
#27 |
I was trying to be anal or insulting, I was sincerely curious if you were talking about one of the newer dsp amps.
#28 |
No, I simply meant a class D. They are not digital and the D doesn't stand for digital but they are still commonly referred to that way. The little Alpine discussed above is a class D. I'm running a pair of Picasso Nano's for front components and a sub.
| FRS Component Out help | Votlon | Electronics | Audio | NAV | Infotainment | 0 | 09-16-2015 11:14 PM |
| Would coaxial door speakers plus stock tweeters be too much high frequency sound? | Prog | Electronics | Audio | NAV | Infotainment | 4 | 12-27-2013 08:15 PM |
| [WA] Kicker CSS65 coaxial speakers x 4pcs | Fizz | Australia Classifieds | 0 | 06-18-2013 10:30 PM |
| Component question | Gen | Electronics | Audio | NAV | Infotainment | 1 | 11-07-2012 01:55 PM |
| FRS Fuel System Component Walkthrough | DeatschWerks | Engine, Exhaust, Transmission | 8 | 09-21-2012 01:09 PM |
