Old 08-20-2012, 11:02 AM   #1
DeatschWerks
Drives: Shop Cars
Send a message via AIM to DeatschWerks
FRS Fuel System Component Walkthrough
FRS OE PORT Fuel System Review…
To look at the future possibilities of the FRS engine, we first need to understand where it starts. Below is a walkthrough detailing some of the OE fuel system components on the FRS.
PART 1: PORT FUEL INJECTORS
Scion PN: SU-003-003-26
Manufacturer: Denso
OE PN: 2040
Testing Data:
Flow Data Summary:
Static Flow: 205cc/min at 43.5psi (3bar)
Spray Pattern: dual beam – split V (~10*)
Dynamic Flow: see reports for detailed flow data
Injector Description:
The Denso injector used in the FRS is different from a lot of other injectors. The injector utilizes a 11mm upper o-ring, sumitomo electrical connector, and a high impedance 12.3ohm coil, which is all fairly common. However, the injector body is very short (40mm functional length) and the nozzle is extended 20mm. This yields an overall overall length of 68mm.
Pictures:
FRS injector (side view)
FRS injector nozzle (bottom view)
FRS injector connector (top view)
PART 2: FUEL PUMP MODULE
Scion PN: SU-003-01-018
Manufacturer: Denso
OE PN: 291100-0090
Testing Data:
Module Description:
The module (aka bucket, aka assembly) is fairly standard in size, shape, and design. The FRS fuel system appears to be returnless because there is only one outlet on the module (see pics). There is an internal regulator that keeps the system pressure a constant 4 bar (58psi), which also indicates a returnless system. I am not aware of another manifold referenced regulator anywhere else in the system. There is also a post fuel pump filter integrated into the module. Both the pump and internal regulator are held into place with a special pre-filter (aka sock) that has integrated clips. Fuel pump modules often have an effect on flow rates. Therefore the OE pump was flow tested both installed into the module and outside of the module. See the report for detailed flow results.
Pictures:
FRS module – assembled (side view)
FRS module – assembled (top view)
FRS module - opened
PART 3: FUEL PUMP
Scion PN: NA – only sold with module
Manufacturer: Denso
OE PN: 291100-1050
Testing Data:
Pump Description:
The first obvious thing to note is that the fuel pump is very small. The overall length is 96mm and the diameter is 38mm. Other than the size, the pump is pretty normal. It features a single stage, single row turbine impeller, internal check valve to hold system pressure and a spring and disc style PRV (pressure release valve). The connector is not a standard style. When tested, the pump operated very quietly and smoothly drawing very little current, but also flowing quite modestly. The PRV begins to opens at 50psi which is interesting given that the internal regulator is set for 58psi. The PRV does not bleed off a lot of fuel so effects on flow are pretty minimal.
Pictures:
FRS pump (side view)
FRS pump inlet
FRS pump outlet
DeatschWerks is offline   Reply With Quote
Old 08-20-2012, 12:16 PM   #2
Don@Accelerated
Don@Accelerated's Avatar
So whats the plan here? We plan on making some HP?
Don@Accelerated is offline   Reply With Quote
Old 08-20-2012, 12:21 PM   #3
DeatschWerks
Drives: Shop Cars
Well...we mapped the OE fuel system so we could see where it can be improved.
We do have some "improving" in the works and should have something available quite soon.
Old 08-20-2012, 12:29 PM   #4
Jeremiah@MPG
Drives: 2003 350z TT
Send a message via AIM to Jeremiah@MPG
Good news! Glad to see you guys getting in on the fuel side of things for the platform.
Jeremiah@MPG is offline   Reply With Quote
Old 09-21-2012, 03:37 AM   #5
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
thanks cant wait to see your results
20valvewynn83 is offline   Reply With Quote
Old 09-21-2012, 07:27 AM   #6
mike2100
mike2100's Avatar
Drives: 23 BRZ
This should be a sticky
mike2100 is offline   Reply With Quote
Old 09-21-2012, 09:21 AM   #7
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
They will just delete it like they did the crawford info on the engine unless they pay as a vendor.
jadewbj is offline   Reply With Quote
Old 09-21-2012, 11:56 AM   #8
djdnz
1337
Drives: 2013 BRZ WRB S/C
Thanks guys, great post
djdnz is offline   Reply With Quote
Old 09-21-2012, 12:09 PM   #9
AJUSA.com
AJUSA.com's Avatar
Great post, awesome information.
AJUSA.com is offline   Reply With Quote
Official Component Weights & Weight Reduction Thread JRitt Tracking / Autocross / HPDE / Drifting 381 10-03-2024 08:02 AM
What fuel do you put on your FRS/BRZ? dhpinoy Southern California 61 06-15-2018 05:35 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
OptionJDM- Cusco Suspension Component OptionJDM Brakes, Suspension, Chassis 27 11-09-2012 11:46 AM
Deatschwerks BRZ Fuel System Review xwd Engine, Exhaust, Transmission 0 08-11-2012 03:47 PM
