Old 11-02-2012, 11:17 PM   #1
Gen
Drives: Scion FR-S
Component question
I purchased some Sony GS1720S (got a good deal at about $100 shipped) and was thinking I'd put the woofer in the doors and 1" tweeter in the dash, with both connected to the crossover.
As I am quite the newbie when it comes to this sort of thing, do you foresee having any problems with this setup? I had heard something about the factory amp not being full range?
Gen is offline   Reply With Quote
Old 11-07-2012, 12:55 PM   #2
PatrickSAN
Drives: SWP GR 5DR
You'll need to measure the actual tweeter size to be sure that it will fit in the OEM tweeter location. If not, you will need to remove the factory 3.5" speaker and install the Sony tweeter in that location.
Just because both are considered a 1" tweeter does not mean that the Sony will fit where the OEM tweeter was located.
You will also need wiring harnesses and mounting harnesses, and you will need to determine a location fo rthe aftermarket crossover. I'd say stash them behind the dash and use the OEM door speaker wire to supply signal to the door-mounted midrange.
You'd have an input to the crossover fromthe OEM HU, then the output would go straight to the tweeters for the highs and tap from the midrange output into the OEM door wires right there behind the dash.
All of that last part is moot if you add an amp.
PatrickSAN is offline   Reply With Quote
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
OptionJDM- Cusco Suspension Component OptionJDM Brakes, Suspension, Chassis 27 11-09-2012 11:46 AM
FRS Fuel System Component Walkthrough DeatschWerks Engine, Exhaust, Transmission 8 09-21-2012 12:09 PM
Lutz Performance | Lowering Component SALE. Diego@lutzperformance Brakes, Suspension, Chassis 4 09-11-2012 01:11 PM
