Old 02-15-2016, 09:28 PM   #15
omfg5041
It's a rubber pad to provide paint protection or some flexibility if you decide to lift something besides the car (example : lifting the engine - which you want to make sure you do it right if you decide to do that)
Sent from my Magic Unicorn using Tapatalk
omfg5041 is offline   Reply With Quote
The Following User Says Thank You to omfg5041 For This Useful Post:
radroach (02-16-2016)
Old 02-15-2016, 09:45 PM   #16
FrostedFlakes
Drives: 2013 Raven FRS
You technically can lift by the pinch welds but they do not hold weight well and can be bent and damaged easily. They are the most fragile pinch welds I have seen on any car.
If you land the car on jack stands, be sure the weight is distributed evenly on both sides or else the welds will bend or damage with the weight sagging all on one side.
My observations is that these pinch welds are three sheets of cheap metal pressed together to form the rocker area. It's a horrible design. I have seen cheap Hondas with better pinch welds than that.
As most mentioned..jack the car on the mentioned jack points...look it up on the DIY section some where. If car is too low to clear your jack, roll it on thicker blocks of wood or ramps to give clearance.
Good luck.
FrostedFlakes is offline   Reply With Quote
Old 02-15-2016, 09:56 PM   #17
omfg5041
I love how people with not education in the Automotive field are telling someone thats been in the trade for 4 years now, that he's wrong. Its one of the first things that you learn as a tech. I didn't know that everyone here thats been saying not to lift by the pinch welds were those that built the vehicle and are saying the printed documentation is wrong.
Mr.ac (02-15-2016)
Old 02-15-2016, 10:14 PM   #18
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by bleox View Post
So can I jack it up from here
Yes you can. It will work 100%
Will it damage the car? No, but you'll bend the pinch welds. 100% just cosmitic damage.
Is it ideal? Not really.
You'll be better off cutting some 2x4s to drive on. Then lift from the front/rear jack points.
And to the pinch weld scardy cats, don't be a *****.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
FrostedFlakes (02-15-2016), justatroll (02-16-2016)
Old 02-16-2016, 03:11 AM   #19
bleox
Drives: 2015 Subaru brz
I know I'm supposed to jack from the subframe and diff but the issues was that ones the coils where installed the jack was gonna hit the bumper! But I just went to a shop
bleox is offline   Reply With Quote
Old 02-16-2016, 11:52 AM   #20
Crashdummy
too much is never enough.
Crashdummy's Avatar
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
Jacking from the pinch welds is normal for most cars, I jack all my cars from them and have never had a problem.
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon
Nanako's Mod Thread
Crashdummy is offline   Reply With Quote
The Following User Says Thank You to Crashdummy For This Useful Post:
omfg5041 (02-16-2016)
Old 02-16-2016, 02:16 PM   #21
Nickosport
Drives: 2015 WRB BRZ Premium
I had the same issue when I lowered my car. My standard 3 ton jack was not low enough to get under the front bumper to the jacking point. For an immediate solution, I cut some 2x8 to about 24" long and just drove the front wheels onto them, and the jack slid under.
For a longer term solution, harbor freight sells a 2 ton long reach jack for $140, even less when its on sale:
http://www.harborfreight.com/2-ton-l...ump-60678.html
Its low enough to get under most lowered cars. The jack is heavy, but if you're like me and only leave it in your garage, weight isn't a factor. Its also got a very high lift, which is nice for doing transmissions.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 02-16-2016, 02:24 PM   #22
nunonuna
nunonuna's Avatar
If anyone dont want to cut the wood board, use phone book or thick college text book. I know it may sound so cheap, but it works every time and it is free and easy to store (just throw it to the corner lol)
nunonuna is offline   Reply With Quote
Old 02-16-2016, 02:52 PM   #23
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Originally Posted by omfg5041 View Post
It's fine to lift by the pinch welds. It's what they're there for.
Originally Posted by mav1178 View Post
Contrary to what you believe, the pinch weld areas are actual lift points for the car and can easily support the weight of the car.
-alex
Originally Posted by lukes Frs View Post
Look it up the pinch welds are nothing more than the visible area that the inerr structure weldsto the putter panel but have fun believing common miss beliefs in factors about you that knows for a fact that a pinch weld is for lifting a car look it up a pinch weld is only designed to support the load of the car when itis in pinch weld clamps on a frame machine. Justbecuse you work at advance auto or oriellys auto dosent mean your a car tech lol
Dude, become a mechanic and then tell us that the pinch welds are not for lifting. You can lift any unibody frame by the pinch welds without doing damage to the vehicle. Granted, if they are soft and rusted, then no, don't do that. Since I don't have time to argue with stupid, it might help to look at the following forum link - http://www.ft86club.com/forums/showthread.php?t=10111
I have jacked up this car by the pinch welds and they FOLD OVER immediately.
They CANNOT support the weight of the car unless you have the "puck" device that supports on either side of the pinch.
Drive the car up on a 2X4 and then use the low profile jack to jack on the jack points identified in the manual.
I can almost guarantee that ALL of the people above that said that it is OK to jack by the pinch welds have not done it on this car
justatroll is offline   Reply With Quote
Old 02-16-2016, 02:56 PM   #24
omfg5041
Oh sorry, I forgot that I wasn't lifting by the pinch welds 😒
Old 02-16-2016, 02:58 PM   #25
justatroll
justatroll's Avatar
Now do an experiment:
Let the car down off the LIFT.
Jack it up by one corner with a FLOOR JACK
and watch the pinch weld fold over like a limp ....
Old 02-16-2016, 02:58 PM   #26
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
[ame="https://www.youtube.com/watch?v=Y_VcwWjFf-4"]Exhaust note comparison - stock vs Tomei Expreme 80R - YouTube[/ame]
Jacked up on pinch weld.
Sitting on pinch weld.
-alex
Old 02-16-2016, 02:59 PM   #27
omfg5041
Jacking points?
Dude. I had to lift each individual corner of the car to get the hoist arms under it 😂 fuck you're dumb.
No - the hoist doesn't sit low enough for the arms to swim under it without lifting
Old 02-16-2016, 03:01 PM   #28
justatroll
justatroll's Avatar
I must be SOO dumb that I folded over two of my pinch welds before deciding I should not do that anymore.
I guess the gravity in my area is stronger than yours.
I would go video it doing it again but I don't want to fuckup another one just to prove a point.
Jacking points Qwimby2 BRZ First-Gen (2012+) — General Topics 4 12-08-2015 10:48 PM
Options for Jacking the Vehicle? Stang70Fastback BRZ First-Gen (2012+) — General Topics 15 06-27-2015 04:14 AM
Custom crash with jacking points? JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-07-2014 09:24 AM
Jacking a lowered BRZ/FRS? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-19-2013 03:04 AM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 03:55 PM
