Old 02-01-2016, 09:37 PM   #15
Riftur
Riftur's Avatar
Originally Posted by cdq85 View Post
if you're worried about a 0-60 time in an FR-S, you're gonna have a bad time.
This was purley for a before and after for the install of the K&N drop in filter. Not the actual speed.
Riftur is offline   Reply With Quote
Old 02-01-2016, 10:02 PM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Before: slow.
After: slow.
Source: I have the filter on my car and my car is still slow.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
FRSBRZGT86FAN (02-02-2016), go_a_way1 (02-01-2016)
Old 02-01-2016, 10:16 PM   #17
Riftur
Riftur's Avatar
Originally Posted by mav1178 View Post
Before: slow.
After: slow.
-alex
Lol, i was trying to be a bit more accurate. But the software isnt precise at all. I just did 2 runs from stop lights and i got a 7.2 and a 11. It does have a much better sound. Just ran an errand.
Old 02-01-2016, 10:20 PM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah cold air intakes or even just drop in fliters net like no gains. Some cold air intakes can move the MAF sensor and lean things out a hair for more power but still nothing even worth trying to measure on a dyno let alone a 0-60 with a stop watch.
Tcoat (02-01-2016)
Old 02-02-2016, 12:49 AM   #19
justinsstang
0-60 doesn't matter as much as 40-100 when trying to measure gains. For an inexperienced driver the 0-60 is never consistent anyways. You can vary a lot based on how hard you launch and how much traction you have. The butt dyno is all that matters anyways. I wouldn't worry about times unless it's at a track or strip. I have a 700 horsepower car (not frs) and I have no clue what the 0-60 is lol
justinsstang is offline   Reply With Quote
Old 02-02-2016, 12:56 AM   #20
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I am getting together with a buddy this weekend and I will have him time it on a watch. only problem with that is it adds another 160lbs in my car lol.
To get an accurate 0-60 time you'd need to have a perfect set of conditions as flat a straight as you can find, and something like a VBOX than can accurately calculate the time and also is extremely precise with a high refresh rate. The times you get with a watch or elm 327 dongle app have a higher percent error.
Old 02-02-2016, 01:36 AM   #21
Nessal
Drives: Exige, Miata, Ghia
I only use torque to monitor the OBD functions. Also it's nice to be able to know when the OBD readiness codes are completes before a smog test.
Nessal is offline   Reply With Quote
Old 02-02-2016, 02:27 AM   #22
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
How accurate is the Torque program? I did a 0-60 run in my totally stock 2013 FRS. Well I have cooper tires on the stock rims. I drive the AT cause my wife does not want to learn MT and might need to drive it in a emergency. ONLY IN AN EMERGENCY! lol So the time 0-60 for AT is supposed to be 6.8 or so. I did it in 6.0 sec which does not seem right considering the MT is said to be 6.2. Thoughts?
you got 6.0 seconds? in an AT??? fastest i got in my AT was 7.2, thats with intake and exhaust on summer tires with spare tire delete. are you sure your looking at the right numbers??
mizzta21 is offline   Reply With Quote
The Following User Says Thank You to mizzta21 For This Useful Post:
Old 02-02-2016, 08:55 AM   #23
Riftur
Riftur's Avatar
The 0-60 in the Torque app is not accurate at all I found. Later i did 2 more runs and got a 7 and 11. So that tells you its not accurate at all.
The Following User Says Thank You to Riftur For This Useful Post:
mizzta21 (02-03-2016)
Torque App - 100% Accurate Fuel Remaining B-R-Z Engine, Exhaust, Transmission 0 08-29-2014 05:16 PM
Correcting drive ratio for accurate speed AlexTheGreek Engine, Exhaust, Transmission 25 12-05-2012 02:13 AM
Disp Temperature not accurate marinjim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-22-2012 09:16 AM
How accurate? Maps316 BRZ First-Gen (2012+) — General Topics 18 08-02-2012 09:28 AM
Accurate Engine Impressions S2KtoFT86 Other Vehicles & General Automotive Discussions 1 12-16-2009 01:05 PM
