Old 11-29-2012, 09:04 AM   #1
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
Correcting drive ratio for accurate speed
Hi all,
I'm coming from the motorcycle world (Honda CBR 600/1000). This is my first "toy" car.
When I changed my final drive on my motorcycle, there was a speed sensor on the output of the transmission that I could jack into with a device to correct the speedometer. (SpeedoDRD or SpeedoHealer)
Does such a thing exist for calibrating new tires diameters or differential gear ratio changes so that the speed on the dash is correct? Does the speedometer read the speed from the output of the transmission or does it take it from the ABS which must have individual speed sensors?
And yes I know speedometers are not accurate because of the pull/slip characteristic of tires (Longitudinal Force versus slip ratio) and because of tire growth with increased speed, but I still want to be able to adjust it.
AlexTheGreek is offline   Reply With Quote
Old 11-29-2012, 10:03 AM   #2
cwb48
cwb48's Avatar
Drives: 2013 FR-s Firestorm
I'm pretty sure that this can be done with the Toyota Techstream software and the correct cable plugged into the DLC. Perhaps someone here familiar with the software can verify this.
cwb48 is offline   Reply With Quote
Old 11-29-2012, 10:12 AM   #3
AlexTheGreek
Yeah, but I want to control it myself. I basically want to break into the pulse wave from the hall effect sensor and adjust the frequency with an IC.
Old 11-29-2012, 10:28 AM   #4
wparsons
wparsons's Avatar
Apparently you can get cracked or less feature packed versions of tech stream (with cable) for like $50 on ebay. Not sure how reliable they are, but if they are it's a very good option to have.
flickr
Old 11-29-2012, 10:53 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I got it for $27, cable included. I have no idea if it is one of the features.
Old 11-29-2012, 12:09 PM   #6
AlexTheGreek
Well if you can check I would greatly appreciate it Mr. Sportsguy83!
The Following User Says Thank You to AlexTheGreek For This Useful Post:
Sportsguy83 (11-29-2012)
Old 11-29-2012, 12:16 PM   #7
Sportsguy83
Drives: Limited BRZ
Just to help me, if by tomorrow afternoon I haven't posted anything, please quote me again or send me a PM to remind me.
Old 11-29-2012, 02:18 PM   #8
wparsons
wparsons's Avatar
Which cable do we need? The mini connector with less pins? If you've got a link to the one you bought that's even better!
TechStream can reset the TPMS' right?
flickr
Old 11-29-2012, 02:24 PM   #9
Sportsguy83
Drives: Limited BRZ
I got THIS one because the software version was the latest one.
If I were to do it again, I would get a cable in USA and to get the latest software just go and get it from pirate bay or similar.
The techstream that is running around has been proven not capable of resetting TPMS. We still don't know if it is because its some type of "Techstream lite" or because there is a specific cable the dealer uses we that don't have access or what.
Old 11-29-2012, 02:52 PM   #10
AlexTheGreek
And I'm assuming it's the same hardware for both the BRZ & FR-S?
Old 11-29-2012, 11:07 PM   #11
wparsons
wparsons's Avatar
Hahaha, awesome. The one thing I for sure wanted it for!
flickr
Old 11-30-2012, 08:31 AM   #12
Sportsguy83
Drives: Limited BRZ
Yeah, same hardware and software.
Old 11-30-2012, 10:55 AM   #13
AlexTheGreek
Just downloaded TechStream from the second best website in the world (ft86club.com #1 of course).
But I guess without connecting to the car I can't really check that I can calibrate the speedometer.
I found a cable online. It looks like a 30$ go F yourself for two plastics bits and a wire, but still not bad.
[ame="http://www.amazon.com/16-Pin-V7-11-010-TOYOTA-Software-Techstream/dp/B00AC2FN7Q/ref=sr_1_1?ie=UTF8&qid=1354290894&sr=8-1&keywords=techstream+cable"]Amazon.com: 16-Pin V7.11.010 MINI VCI V7 for TOYOTA Cable & Software TIS Techstream: Electronics[/ame]
Old 12-03-2012, 07:08 AM   #14
Sportsguy83
Drives: Limited BRZ
I played around yesterday with the software, and it is very basic and limited in what can/can't be done.
Basically the only thing that can be done is change the car settings (DRL turn off, light sensonr sensitivity for the BRZ, turn alarm on/off, simple things like that).
There are a lot of options around, but the software just does not work. When you try and access it (like say the TPMS, changing VCT/TRAC features) the software tells you the system is not responding or not available.
This won't do the trick for speed compensation. I didn't even see the option anywhere.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
AlexTheGreek (12-03-2012)
Disp Temperature not accurate marinjim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-22-2012 08:16 AM
How accurate? Maps316 BRZ First-Gen (2012+) — General Topics 18 08-02-2012 08:28 AM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 02:23 AM
Speed hunters first drive and closer look reviews (with photos of modded blue TRD 86) Spaceywilly Scion FR-S / Toyota 86 GT86 General Forum 19 11-28-2011 10:41 PM
Accurate Engine Impressions S2KtoFT86 Other Vehicles & General Automotive Discussions 1 12-16-2009 12:05 PM
