Old 02-01-2016, 05:52 PM   #1
Riftur
Riftur's Avatar
How accurate is Torque program
How accurate is the Torque program? I did a 0-60 run in my totally stock 2013 FRS. Well I have cooper tires on the stock rims. I drive the AT cause my wife does not want to learn MT and might need to drive it in a emergency. ONLY IN AN EMERGENCY! lol So the time 0-60 for AT is supposed to be 6.8 or so. I did it in 6.0 sec which does not seem right considering the MT is said to be 6.2. Thoughts?
Riftur is offline   Reply With Quote
Old 02-01-2016, 05:54 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Not very lol! I would say give or take 1 seconds maybe more.
Old 02-01-2016, 05:55 PM   #3
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Assuming it's using the phone's onboard GPS (can someone confirm?), those are usually 1 Hz, meaning they only update position/speed once a second. Anything between two readings is interpolated.
There's also a lot of other variables at play like temperature, surface conditions, etc. etc.
So in short, not very.
GSpeed is offline   Reply With Quote
Old 02-01-2016, 06:00 PM   #4
Riftur
Riftur's Avatar
Ok didnt think it was very accurate. lol, To bad. I just got my K&N drop in airfilter and wanted to see if there was any diffrence.
Old 02-01-2016, 06:02 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I believe you can choose in the settings whether or not the dials show obd ecu speed or GPS speed and can compare them. But in general torque is not accurate it tends to overestimate things like the virtual dyno feature is a horrible attempt
Also important note a K&N filter would no way yield a .8 second improvement if we're assuming a perfect environment and conditions (launch, tire temp etc) A maximum you'd get is 5 HP according to some dyno tests. I don't think that's near enough to shed .8 of second off an AT.
@Riftur
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
go_a_way1 (02-01-2016)
Old 02-01-2016, 06:16 PM   #6
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
I don't think 6_2 is accurate for stick. I know Ive got to be faster. I say high 5s but I don't have stock primacy tires and all traction is on. Like you I think it's faster. I wonder what FI 86s are doing 0 to 60
I can get 60 pretty quick. Think I'll time it and see. I think if you shift in the upper rpms and you grab the ground, you should be lower than 6 2. Just my thoughts with no science to back it. Yet
RichardsFRS is offline   Reply With Quote
Old 02-01-2016, 06:31 PM   #7
Riftur
Riftur's Avatar
Originally Posted by FRSBRZGT86FAN View Post
I believe you can choose in the settings whether or not the dials show obd ecu speed or GPS speed and can compare them. But in general torque is not accurate it tends to overestimate things like there dyno feature is a horrible attempt
@Riftur
I havent added the K&N when I did the 0-60. I just added it right before I posted the thread. I was planning on doing a 0-60 on my way to work tomorrow.
The Following User Says Thank You to Riftur For This Useful Post:
FRSBRZGT86FAN (02-01-2016)
Old 02-01-2016, 06:33 PM   #8
Riftur
Riftur's Avatar
I am getting together with a buddy this weekend and I will have him time it on a watch. only problem with that is it adds another 160lbs in my car lol.
Old 02-01-2016, 06:37 PM   #9
I am not sure about doing much better than 6.2 even with tires. I also know that I could not tell if doing 6.2 or "high fives" just by sitting there driving.
Cole (02-01-2016), finch1750 (02-02-2016), FRSBRZGT86FAN (02-01-2016), go_a_way1 (02-01-2016), Marco_86 (02-01-2016)
Old 02-01-2016, 06:48 PM   #10
ARTBRZ
Aloha!
ARTBRZ's Avatar
Twerk program.....
http://wifflegif.com/gifs/542162-rub...sian-girls-gif
Not good at all.
ARTBRZ is offline   Reply With Quote
Old 02-01-2016, 06:58 PM   #11
Riftur
Riftur's Avatar
Originally Posted by ARTBRZ View Post
Twerk program.....
Not good at all.
Actually thats way better than the program I use lol
ARTBRZ (02-04-2016)
Old 02-01-2016, 07:03 PM   #12
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
if you're worried about a 0-60 time in an FR-S, you're gonna have a bad time.
cdq85 is offline   Reply With Quote
The Following 6 Users Say Thank You to cdq85 For This Useful Post:
FRSBRZGT86FAN (02-01-2016), go_a_way1 (02-01-2016), Marco_86 (02-01-2016), Tcoat (02-01-2016), TheVoiceOfReason (02-01-2016), YamahaR86 (02-01-2016)
Old 02-01-2016, 07:04 PM   #13
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
lol.
The Following 4 Users Say Thank You to Sarlacc For This Useful Post:
FRSBRZGT86FAN (02-01-2016), go_a_way1 (02-01-2016), Tcoat (02-01-2016), YamahaR86 (02-01-2016)
Old 02-01-2016, 07:17 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The program is only as accurate as the device being used to measure... in this case, your phone.
-alex
Torque App - 100% Accurate Fuel Remaining B-R-Z Engine, Exhaust, Transmission 0 08-29-2014 04:16 PM
Correcting drive ratio for accurate speed AlexTheGreek Engine, Exhaust, Transmission 25 12-05-2012 01:13 AM
Disp Temperature not accurate marinjim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-22-2012 08:16 AM
How accurate? Maps316 BRZ First-Gen (2012+) — General Topics 18 08-02-2012 08:28 AM
Accurate Engine Impressions S2KtoFT86 Other Vehicles & General Automotive Discussions 1 12-16-2009 12:05 PM
