AVOturboworld
Old 07-30-2013, 08:34 AM   #2675
Senna
Senna's Avatar
Drives: 12' Jeep Rubicon 08' 997 Targa 4S
Standing water
Hey guys is there any chance of screwing turbo up when going through heavy rain and standing water?
Senna is offline   Reply With Quote
Old 07-30-2013, 08:42 AM   #2676
mrk1
Drives: Sterling BRZ Ltd
I wouldn't think so. The air intake is factory so you should be ok there. With the metal under tray installed the turbo is pretty well covered. My buddy has a 997 Turbo and his are just hanging out under the motor and they don't have any issues with water.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-30-2013, 09:15 AM   #2677
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'd be cautious of just having ran the turbo good (exhaust glowing red), and going through standing water right after. Thermal shock will not be pretty.
Having said that, if you plan on going through standing water deep enough to reach the turbo, you have other problems to deal with....
Old 07-30-2013, 10:03 AM   #2678
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by AVOturboworld View Post
I've been seeing here and there comments about how "tiny" the turbocharger that we use is, and I have to admit, it irks me. Because it is, if anything, on the large size for somebody doing a daily driver build on a 2.0-liter motor. OEM turbochargers are much smaller and run out of breath much sooner, while we've been pushing past 300whp (wheel, not crank) at 10~11psi on 92 octane fuel. That's still 4~6psi before the turbo starts running out of breath.
If you are refering to me, then I apologize. I don't completely understand what turbo you are using. I just thought it was slightly smaller than a GT2871R which I don't consider a large turbo either. I guess the reason is that I can look up the stats on an off the shelf turbo, but I believe your kit comes with a custom turbo, and I haven't seen the stats on it.
Old 07-30-2013, 10:09 AM   #2679
Sportsguy83
Drives: Limited BRZ
It's in the OP
AVO18/49 Turbocharger with 5-7psi actuator - compressor wheel size 49.2/56 | exhaust wheel size 50.5/68
Old 07-30-2013, 11:02 AM   #2680
buditjoenawan
Drives: Very very slowly
David,
Are you going back to Toni's to get the car retuned without an exhaust leak?
-budi
buditjoenawan is offline   Reply With Quote
Old 07-30-2013, 11:13 AM   #2681
Sportsguy83
Drives: Limited BRZ
Originally Posted by buditjoenawan View Post
David,
-budi
I got the exhaust leak fixed last week by @KAB-FRS. Cars feels completely different
Old 07-30-2013, 02:39 PM   #2682
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
I think a core issue here is CHRA sizing. The 2871R, for instance, is a catch-all for about 17 different CHRA combinations on the Garrett catalog. We use two different types of the 2871, one that's good for about 39lb/min, and another that is good for 42~44lb/min depending on hotside. The turbo in our BRZ/FR-S turbo kit performs nearly as well as the 44lb/min 2871 CHRA from our testing, though it does get choked down at the upper boost levels (past 16psi). But then, for that matter we can run the larger 2871R at 45psi on the diesel racing trucks with our larger stainless steel hotsides.
We just believe in right-sizing a turbocharger for optimal performance. We could certainly throw a larger turbocharger at the twins, but daily driving enjoyment will suffer. Some people have different needs though, and I respect that.
AVOturboworld is offline   Reply With Quote
Old 07-30-2013, 02:41 PM   #2683
AVOturboworld
When I came back from SEMA last year on the maiden voyage of battleship AVO, the very last bit was about 2 hours through monsoon level rain at 70-ish mph, hydroplaning through rather deep puddles. That was about 10 months ago, no issues at the time, no issues since.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
ill86 (07-31-2013), Sportsguy83 (07-30-2013)
Old 07-30-2013, 02:57 PM   #2684
buditjoenawan
I would think that 15psi is a tad high. Get it retuned!
-budi
Old 07-30-2013, 03:02 PM   #2685
Sportsguy83
Drives: Limited BRZ
Definitely, I am confident of driving the car through a storm.
Old 07-30-2013, 03:02 PM   #2686
Sportsguy83
Drives: Limited BRZ
-budi
Oh wait wait.. I was reading this wrong!!!
Edit:
I am not hitting 15 psi.
I'm at the same 13 psi. I will be doing around 15 psi with E85 soon.
Old 07-30-2013, 03:06 PM   #2687
buditjoenawan
I don't understand what you mean...
Oh, last dyno I saw was when you were tuned at FA20club and it showed a peak of 15psi? That was with the exhaust leak right? So if the leak is fixed, then your turbocharger would be spinning faster right?
-budi
Old 07-30-2013, 03:08 PM   #2688
Sportsguy83
Drives: Limited BRZ
-budi
Peak HP run was done with 14 psi.
I dialed it down to 13 psi before leaving the Dyno.
I have been hitting the same 13 psi after leak fix.
either way, new calibration will happen soon.
My bad, I had not read your question properly.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
