12-08-2014, 08:12 AM | #2451 | |
The Following User Says Thank You to captain_jack For This Useful Post: | KraftWerks (12-08-2014) |
12-08-2014, 08:53 AM | #2452 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
Sent from my SM-N900T using Tapatalk EDIT: Wow talk about customer service, nice quick reply from CJ, hope his solution will work.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler Last edited by zoth; 12-08-2014 at 11:44 AM. |
The Following 2 Users Say Thank You to zoth For This Useful Post: | KraftWerks (12-08-2014), SPCorBUST (12-08-2014) |
12-08-2014, 01:13 PM | #2453 |
Drives: 2013 Scion FRS
Same here - The customer service from Kraftwerks and CJ remains to be top notch!
Thanks CJ!!
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
The Following 5 Users Say Thank You to nlowell For This Useful Post: | captain_jack (12-08-2014), KraftWerks (12-08-2014), Scracho (12-08-2014), xDanger_208x (12-08-2014), zoth (12-08-2014) |
12-08-2014, 01:18 PM | #2454 | |
Service folks over there are great. CJ gets a lot of props, but Joe is great too!
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
The Following 2 Users Say Thank You to SPCorBUST For This Useful Post: | captain_jack (12-08-2014), xDanger_208x (12-08-2014) |
12-08-2014, 01:27 PM | #2455 |
They have a new billet bypass that they ship with new units - they are sending the newer part to replace the plastic bypass to see if that fixes it. I'll report back as soon as I try.
12-08-2014, 01:29 PM | #2456 |
Thank you sir. Even if it doesn't work for you, it might work for others. Crossing my fingers for you though!
12-08-2014, 01:40 PM | #2457 |
Drives:
Top notch service!
In fact, I just received my c38 kit about 5 min ago!!!!
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
The Following 4 Users Say Thank You to xDanger_208x For This Useful Post: |
12-08-2014, 01:45 PM | #2458 |
Drives: 2018 Subaru BRZ
That's exciting!
On my fourth 86... and everything in between
12-08-2014, 02:02 PM | #2459 |
Nice! Make sure you do the inventory check - if you are missing something, it's early enough that they might be able to get it out today. And don't forget to clamp or zip tie those hoses as others have mentioned, otherwise good luck with the install!
The Following 2 Users Say Thank You to SPCorBUST For This Useful Post: | Rulin (12-08-2014), xDanger_208x (12-08-2014) |
12-08-2014, 02:06 PM | #2460 | |
Drives: Kraftwerks BRZ
The Following User Says Thank You to KraftWerks For This Useful Post: | SPCorBUST (12-08-2014) |
12-08-2014, 02:13 PM | #2461 | |
Drives:
My STX build thread
12-08-2014, 02:29 PM | #2462 |
I should probably do the same considering everything is still in the box and I received last week.
12-08-2014, 06:46 PM | #2463 |
Drives: 2013 whiteout Frs
Will the install be easier with the radiator off I'm swapping to the skunk alpha.
12-08-2014, 07:21 PM | #2464 | |
Drives:
My STX build thread
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
