Old 12-08-2014, 08:12 AM   #2451
captain_jack
captain_jack's Avatar
Originally Posted by nlowell View Post
ok, so I think I have an issue with my Bypass Valve. When I am partial throttle at around 5k RPM I get a very loud hissing noise that continues to get louder until I either shift or go WOT. I did some testing tonight and it appears my bypass is staying open under partial throttle situations when my boost gauge is registering anywhere from -12 to +2 or +3. The higher the RPM, the more positive boost it takes to close the bypass. While in theory, this makes sense, from what I have read it means that I need a stronger spring on my bypass valve to keep it closed under those situations. As I understand it, the bypass should only open when I am not on the throttle at all.
Can someone help me out here? Anyone else with this situation? Is the spring even upgradable or do I need a new bypass?
Here is a partial throttle video where you can hear the hissing of the bypass:
Mine had the same hiss actually. We initially thought it was a boost leak but narrowed it down to the bypass valve. I'm winding if upgrading to the metal housing unit would solve that
Old 12-08-2014, 08:53 AM   #2452
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Same here, I just assumed it was my cusco catch can. I guess not.
Sent from my SM-N900T using Tapatalk
EDIT: Wow talk about customer service, nice quick reply from CJ, hope his solution will work.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 12-08-2014, 01:13 PM   #2453
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Same here - The customer service from Kraftwerks and CJ remains to be top notch!
Thanks CJ!!
nlowell is offline   Reply With Quote
Old 12-08-2014, 01:18 PM   #2454
SPCorBUST
SPCorBUST's Avatar
Care to share? In case anybody else needs it.
Service folks over there are great. CJ gets a lot of props, but Joe is great too!
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 12-08-2014, 01:27 PM   #2455
nlowell
nlowell's Avatar
They have a new billet bypass that they ship with new units - they are sending the newer part to replace the plastic bypass to see if that fixes it. I'll report back as soon as I try.
Old 12-08-2014, 01:29 PM   #2456
SPCorBUST
SPCorBUST's Avatar
Thank you sir. Even if it doesn't work for you, it might work for others. Crossing my fingers for you though!
Old 12-08-2014, 01:40 PM   #2457
xDanger_208x
xDanger_208x's Avatar
Drives:
Top notch service!
In fact, I just received my c38 kit about 5 min ago!!!!
xDanger_208x is offline   Reply With Quote
Old 12-08-2014, 01:45 PM   #2458
Scracho
Drives: 2018 Subaru BRZ
Originally Posted by xDanger_208x View Post
Top notch service!
That's exciting!
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 12-08-2014, 02:02 PM   #2459
SPCorBUST
SPCorBUST's Avatar
Top notch service!
Nice! Make sure you do the inventory check - if you are missing something, it's early enough that they might be able to get it out today. And don't forget to clamp or zip tie those hoses as others have mentioned, otherwise good luck with the install!
Old 12-08-2014, 02:06 PM   #2460
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
@xDanger_208x still plenty early. Shoot me a PM if anything is out of place or you simply have any questions.
KraftWerks is offline   Reply With Quote
Old 12-08-2014, 02:13 PM   #2461
xDanger_208x
Drives:
I'll be at work all day, so I'll do a check tonight.
Old 12-08-2014, 02:29 PM   #2462
Scracho
I should probably do the same considering everything is still in the box and I received last week.
Old 12-08-2014, 06:46 PM   #2463
Barbas
Drives: 2013 whiteout Frs
Will the install be easier with the radiator off I'm swapping to the skunk alpha.
Barbas is offline   Reply With Quote
Old 12-08-2014, 07:21 PM   #2464
xDanger_208x
Drives:
@SPCorBUST which hoses need clamped??
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
