#2045 |
Drives: 2014 FR-S MT Asphalt Grey
I'm sure this has been covered but I couldn't find the exact offsets I'm thinking of. Here is what I am thinking of running:
Drag DR-38 Wheels 17x8 with 225/45R17 Tires Front Offset- 47 Rear Offset- 35 I plan on eventually dropping 20mm front and rear but not right away. Should I do the staggered offset or not? Thanks. |
#2046 | |
1337
Drives: 2013 BRZ WRB S/C
You should be just fine with the 17x9+38 / 255/45, just watch out if you start to add camber. |
#2047 | |
1337
![]() Here's some examples of +35: Lowered 1.25" http://www.ft86club.com/forums/showthread.php?t=43621 Stock height (with 215 tires, too stretched!) ![]() http://www.ft86club.com/forums/showt...t=43621&page=2 Lowered ??" http://www.ft86club.com/forums/showthread.php?t=34376 Here is 17x8.0 +48 for comparison: stock height ![]() ![]() http://www.ft86club.com/forums/showt...t=11493&page=2 At stock height yes it pokes ever so slightly, but lowered there will be absolutely no comparison, the +35 is the way to go. Staggered offset will only make rotating wheels impossible (unless you want to poke the front and suck the rear) Last edited by djdnz; 01-03-2014 at 06:02 PM. |
#2048 | |
Drives: '13 BRZ
#2049 | |
1337
I should clarify you are definitely on the edge with fitment (mainly the 255 RS3 tire), but I think it will be good. I have 18x9+42 with 245/35/18. There was approximately 3mm clearance with stock suspension. With your 17x9+38 you will get an additional 4mm but the tire is wider so you lose some of what you gained. Either way it should fit. When you mount them just make sure you have some clearance to the stock spring perch, that should be your only real concern. If there is not enough clearance a shim spacer of 3mm is your best bet. |
#2050 | |
Drives: 2013 Raven FR-S
Sent from my HTC One using Tapatalk
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
#2051 |
Drives: '13 BRZ
I was mostly wondering if anyone could tell me if I definitely need spacers or no. Since this is such an odd tire size for the brz, I guess I'll just have to put them on and see.
#2052 | |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
#2053 |
Drives: 13 FR-S
18x8 +35 wheels. Stock ride height. I like the flush look, or close to it. Will 245/45 tires work for what I'm looking for. If not, what will?
#2054 | |
Drives: 2013 scion FRS
im will be running the same set up but not worried about going really low, i will have RS-R coilovers, and also would like to know what the meatiest tire i can run with out major fender work being done, i dont mind rolling the fenders, just prefer not to. thanks for answering both our questions in advance |
#2055 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
However be prepared that you car will have an "offroadish" look with the new setup, so you may want to consider at least an 1" drop with springs.
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#2056 | |
Drives: Rx7
Mark Ravspec |
#2057 |
#2058 |
Drives: 2013 Raven Scion FR-S
Alright guys I'm admittedly super new to all of this so feel free to flame if you must!
I'm really interested in 18x8.5 5x100 offset +48 (rear) WedSports SA-15R's for the rear. I'd like to wrap them in Hankook Ventus RS-3 275/35ZR18. I'm about 99% certain this will fit after research. (Wheel) (Tire) I'd like to do smaller width wheels (Maybe 18x7.5?) in the front with the same tire only in a size that fits. (Is 215/45ZR17 the right size for that?) I also currently am still riding on the 100% stock suspension but will be moving to something adjustable here probably late summer (Can't afford to do all of this at once unfortunately) and I'd like to do a 1" drop. I don't want to slam anything or even completely eliminate the wheel gap, I just want meaty wheels with no rub and ultimately a better ride. If anyone could help me figure out if this would fit first with the stock suspension setup and/or let me know if I need to wait until I can buy something more adjustable to make it all work. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
