Old 01-22-2014, 03:10 AM   #155
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by moK View Post
Thanks for the super quick reply. In that case, any idea why Write would still be grayed out?
I looked at your stock ROM and it is identical to the stock ROM in the database so it should work like everyone else. Did you delete (press the red X button) all of your existing modified ROMs in the Upload Data section of OpenFlash Manager? And after X-ing them out, did you press Start to upload the new changes to the OFT? If not, that is the problem.
Once they are all deleted, just load the v1.54 .dev file and connect the OFT to your car. Go to Tuning and then to Write. It should be selectable and you should see 5 tune file options to choose from.
Shiv
Old 01-22-2014, 03:47 AM   #156
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by shiv@vishnu View Post
You should be good to go now with the v1.54 download. I updated the stock A00G file with your original ROM
Cheers,
Shiv
Thank you! 'Write" button is working, bot now OFT offers me to write all A01G roms and it seems suggests that i have now Stage 2 EL in my ECU (as this file marked with *). I am a bit scared to load 01G file to my 00G ECU - will i be able to start then? And will i be able to load my original 00G ROM back to ECU if
i write it with 01G now?
Please advise if i should still write 01G tune if OFT allows me to.
Cheers,
Andrey
Ondreiko is offline   Reply With Quote
Old 01-22-2014, 03:51 AM   #157
Shiv@Openflash
Drives: 2013 FRS
Cheers,
Andrey
The OFT doesn't remember the file you last loaded, only the memory slot that it came from. So that is why you are seeing the * where it is. In cases where you just loaded new maps to the OFT, this * is meaningless.
Go ahead and upload, everything will be fine. Your original ROM (A00G) is still saved on the OFT. So you can still go back to it when needed
Shiv
Old 01-22-2014, 04:04 AM   #158
moK
Drives: White BRZ
Shiv
Just figured it out and in the process of writing I noticed I had the exact same problem as Cross, my FW version was reported as 1.21 in the upper right corner of OFM while the Download and Upload windows reported 1.14. I restored the car to stock rom, reset OFT, reinstalled OFM, and read the stock. Not sure if all those steps were necessary but it looks like it worked!
moK is offline   Reply With Quote
Old 01-22-2014, 07:43 AM   #159
Ondreiko
RWD addicted
Ondreiko's Avatar
Shiv
So i just flashed A01G - the car started. Didnot drive it yet. But it is working!
Thank you.
Old 01-22-2014, 08:12 AM   #160
brn12345
brn12345's Avatar
shiv@vishnu Still having trouble with my OFT since my last post on the 9th of Jan. Emailed you yesterday with more details but to just summarize here. I cant communicate with the car as it gives me a "Tuning file mismatching" error. I cant erase the OFT device as it gives me a "cant erase device until original is written to ecu". I cant upload or download maps to the OFT as it gives me "error 0x63 while communicating with the device". I also cant download the log from the device (it starts downloading then stops and the software freezes).
What I can do is connect and view live data, download datalog files in openflashmanager, upload DEV files to the device.
I have been trying by uninstalling the software and reinstalling, tried another PC, waited for an update which came out 1.06 but still the same problem remains. I do need to get this sorted asap. Please help.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 01-22-2014, 08:14 AM   #161
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
4 degrees, the coldest it has been since I started running e85. It took about 5 tries to get it to fire this morning. It wanted to each time but just barely couldn't.
Also, is it normal that LTFT goes to about +4% when at idle but -10% on low load cruising?
Luckrider is offline   Reply With Quote
Old 01-22-2014, 09:12 AM   #162
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Send some cold weather this way....it's been around 104 degrees F past few days!!!
Fizz is offline   Reply With Quote
Old 01-22-2014, 09:15 AM   #163
Luckrider
Luckrider's Avatar
How about we trade for just one day. I love my snow and doorless/topless Jeeping weather.
Old 01-22-2014, 10:08 AM   #164
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
Shiv,
I took my car in for service at the dealer yesterday because my car had been randomly having trouble starting and throwing a code (P0193). Was using the 1.42 beta map but flashed back to stock before taking it in. The code seemed to indicate a fuel pump problem from searching online, but the service manager said they couldn't find anything mechanically wrong and flashed an update to the ECM citing an "out of range error".
I got home, wiped the tablet with the OFM software, and read the stock ROM on the car. Previously I had an ZA1JA01C ROM, and after the update it's showing ZA1JB01C.
Is it possible that the trouble I was having was related to the 1.42 ROM? My plan for now is to leave the car with the stock ROM for the next two weeks or so and see if the problem went away, if so I'll flash the latest release out by then.
My experience brings up an interesting question...if someone has a very old ROM type, could they simply go to the dealer and get their ECM updated to a more recent type and potentially have an easier time flashing with OFT?
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 01-22-2014, 12:23 PM   #165
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
Stage 1 data log done on 1.53b, 25 miles after flash, 91 oct, header back + intake mod.
Comments apprecieated.
http://www.datazap.me/u/danklvr/153b...2&zoom=192-378
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 01-22-2014, 01:42 PM   #166
Ondreiko
RWD addicted
Ondreiko's Avatar
Been driving v. 1.5 whole day long, done 100 miles at least.
And i have to say it feels good! I almost hear how wide my valves are opening on 3k-4k range (if this is not my header gets unbolted). Waiting for ECU to learn more to receive more better feelings. Despite i flashed A01G rom into A00G ecu it is working well.
Thank you, Shiv!
You are leading us onto right direction, i guess.
But please make Adv.Multiplier logging option available for G-series too.
The Following 2 Users Say Thank You to Ondreiko For This Useful Post:
Robert@Openflash (01-22-2014), Shiv@Openflash (01-22-2014)
Old 01-22-2014, 01:50 PM   #167
Malt
Drives: 2015 WRX
Thank you, Shiv!
Flashing A01G is an upgrade as you got the improvements that the factory implemented to fix the DI seals issue.
Malt is offline   Reply With Quote
Old 01-22-2014, 02:25 PM   #168
Shiv@Openflash
Drives: 2013 FRS
Looks really good.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Danklvr (01-22-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 04:26 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-14-2014 12:14 AM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 11:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
