Old 06-10-2013, 11:37 PM   #1
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Koni Strut Blown
I had my Koni front struts blow on RCE Yellows after about maybe 1k miles. Will check with the shop that did the install to see if they'll warranty it or if Koni will warranty it, but I'm stumped. The Koni's seemed like a great product, and I can't believe they failed. They were at half turn from full stiff and installed by a reputable local shop (Works).
Driver's side strut appears to be ok, if you push down on the top-most rubber nib on the top mount, it's completely dry. Passenger side is still leaking fluid.
Are you not supposed to use stock top mounts with the Konis? What do you guys think is going on? I haven't touched the struts since the install.
Edit: Looks like it's time to warranty.
vubaru is offline   Reply With Quote
The Following User Says Thank You to vubaru For This Useful Post:
flippy (06-11-2013)
Old 06-10-2013, 11:50 PM   #2
whataboutbob
AutoX-10/10ths every run
Ouch.
Build thread:Here
Old 06-10-2013, 11:58 PM   #3
Asphalt~86
Drives: Asphalt AT
Asphalt~86 is offline   Reply With Quote
The Following 6 Users Say Thank You to Asphalt~86 For This Useful Post:
Anthonytpt (06-11-2013), B-R-Z (05-06-2015), DriftEightSix (03-04-2014), Enraged21 (06-11-2013), fuddbutter (06-11-2013), suaveflooder (06-11-2013)
Old 06-10-2013, 11:59 PM   #4
vubaru
Now with Boost!
vubaru's Avatar
Originally Posted by whataboutbob View Post
Ouch.
Was hoping for more input than that! Obviously we have a failure here but I'm trying to figure out what may have caused what...
Old 06-11-2013, 12:02 AM   #5
suaveflooder
Not a lot to tell you unfortunately. Just a bad strut. It does happen. My stock strut failed right around a thousand miles as well. I would just have Koni replace it for you.
Can you pull that rubber top off and give us some pics of inside?
suaveflooder is offline   Reply With Quote
The Following User Says Thank You to suaveflooder For This Useful Post:
vubaru (06-11-2013)
Old 06-11-2013, 12:02 AM   #6
OrbitalEllipses
Drives: Attitude
Koni warranty time!
vubaru (06-11-2013)
Old 06-11-2013, 12:03 AM   #7
vubaru
Now with Boost!
vubaru's Avatar
So you think I'm looking at a product failure as opposed to improper install? Obviously I haven't posted photos of the entire assembly but everything appears to my eyes to be installed properly, although I haven't torn things down yet.
Good news is the rears appear to be fine.
Not only do I need new front struts but top mounts, too! ugh..
Those of you who know me, know the amount of ridiculous crap I've had to deal with in my project, and this is just par for the course. Kind of hilarious when you think about it.
Front Struts: 0, My Car: 4*.
Last edited by vubaru; 06-11-2013 at 12:06 AM. Reason: Front stocks blew on RCE's*
Old 06-11-2013, 12:14 AM   #8
suaveflooder
Love Koni's. I ran them in my M3 and LOVED them. You might not be able to run that top rubber piece with that tab. Can you post pictures without the rubber cap? There isn't a lot that can be installed wrong on them, so I would bet product failure.
Give Koni a call. I'm sure you will be taken care of
vubaru (06-11-2013)
Old 06-11-2013, 12:25 AM   #9
vubaru
Now with Boost!
vubaru's Avatar
Funny thing is I loved these at first then the ride quality started deteriorating...hmm..wonder why!
I bought them off a dealer on this forum so I'll contact him first then take it from there.
These are the stock top mounts, I don't think the top part can be removed, although I'm not an expert at suspension so I'll check it out tomorrow.
Old 06-11-2013, 12:36 AM   #10
simpleisbest
Senior Citizen
Drives: Scion FR-S
They look installed correctly. The part where the shock is protruding is the rubber cover that covers the top nut. You can peel that off to reveal the shock adjuster. Looks like shop poked a hole in the cover to allow the adjuster to poke through while protecting the top mount bearing from dirt and dust. Nothing wrong there. Best find out if both fronts are leaking before contacting Koni.
simpleisbest is offline   Reply With Quote
Old 06-11-2013, 12:37 AM   #11
suaveflooder
Here you go. Now go take us pics
Old 06-11-2013, 12:47 AM   #12
vubaru
Now with Boost!
vubaru's Avatar
Duh...easy enough. My crappy cameraphone doesn't have a flash so I'll take some tomorrow.
Hopefully I won't need new top mounts at least
Old 06-11-2013, 12:49 AM   #13
suaveflooder
:happy0180:
Old 06-11-2013, 01:37 AM   #14
OrbitalEllipses
Drives: Attitude
When you get the strut top off, look at the washer at the base of the adjustment blade. One of my struts was leaking from the adjuster out of the box because the o-ring seal beneath wasn't seated. Koni warrantied the strut, but took their sweet fucking time.
KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni Circuit Motorsports Brakes, Suspension, Chassis 115 08-30-2013 11:29 AM
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings raul Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 05-24-2013 09:33 AM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
Hit pothole blew tire.... now have odd sound clayrush Issues | Warranty | Recalls / TSB 15 08-24-2012 12:57 AM
Accidentally blew the dash speakers bladesamurai Electronics | Audio | NAV | Infotainment 15 06-20-2012 10:25 AM
