| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1485 | |
Drives: ...
Am I gonna get anymore clearance in the front with 17x8+45 instead of 17x9+35, or is it not worth the hassle and shall I run 17x9+35 square? |
#1486 |
Drives: Whiteout FR-S
#1487 |
Drives: ...
Tire rack only has the +45 offset so I'm not sure... with some more searching around I could probably find something
#1488 | |
Drives: ...
just found this link: http://www.ft86club.com/forums/showthread.php?t=10257 seems like 17x8+45 wl be ok for the front... |
#1489 | ||
VehicleDynamicsSpecialist
Drives: iG FR-S
Different handling characteristics square to stagger. Plus tire rotations to consider. Your choice, bro.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#1490 | |
Drives: iG FR-S
I would rather have a 8" +35 than a +45. But that's just me. (And JB lol)
| The Following User Says Thank You to ill86 For This Useful Post: | JoeBoxer (06-09-2013) |
#1491 |
Drives: iG FR-S
@onthemove, where in PA are you? I am on the western side if you need help.
#1493 | |
Drives: 2000 Integra LS, 2013 FRS Firestorm
Spacers?
Scion FRS dropped by Tein S Springs - website states 1.3 for front / 1.1 for rear Stock struts/ shocks Enkie Kojin wheels 18 x 9.5 square set up. Tires are Yokohama 255x35 18 I have read that spacers would be needed for the front end to clear the struts. How much is needed to make this work ? Side note : car is mainly for daily driving only. Thanks in advance |
#1494 | |
Drives: '13 BRZ Ltd WRB
If you're using camber bolts, these will change the distance to the perch. Using a bolt in the lower hole gives just a smidge more clearance as opposed to using the top hole. Probaby just a couple of mm, but that can make all the difference. I'm going off of fitment of my 17x8s (+48) with 225. Tire is almost rubbing the perch, but with an 18, I think the rim itself will be in that area. Where am I getting the +30 from? http://forums.nasioc.com/forums/show....php?t=2421193 These guys are running 18x9.5 +30 with 265s, originally this was on stock suspension and camber bolts in the lower holes, then they went to lowering springs (MachV ~1"). They said they had minimal rubbing, which I think was fixed with more negative camber.
| The Following User Says Thank You to 2point0 For This Useful Post: | j2digit (06-10-2013) |
#1495 | |
i believe the offset is 45 , thanks again |
#1496 |
Drives: 2013 Scion FRS
does anyone know if WORK Kiwami CR Ultimate 5x100 18x9.5 +38 will fit on stock suspension? i wont be getting coilovers for at least 6 months so need to find out if stock suspension will work.
#1497 |
Yes. (Please read back through this thread, this fitment has been discussed a number of times as to how it clears, but just. This is my current setup as well)
| The Following User Says Thank You to jshadeck For This Useful Post: | Verge (06-10-2013) |
#1498 |
do you have any pics so i can see how they fill out??
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
